Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 07-21-2020, 10:58 AM   #1
KJSR
KJSR's Avatar
Our 1965 K10 Suburban Project
I had noticed a early Suburban parked in a gated towing/storage yard by my house for a couple of months. Finally I drove by and the gate was open so I stopped. In speaking with the guy who owned it, it was removed from someones property. The new owner planned to cut the top off and make it into a "hunting rig". I was able to change his mind and spent more than what I thought I should but I hated to know the potential fate.
The original owner had passed and his son was cleaning the property. The old man must have been a hoarder...the truck was packed with junk. We were able to find the OG owners manual and the warranty card.
Our plan is to get it running and driving, test the 4wd and see whatever else it needs. After that I will move on to some type of build and plan to do a separate thread.
My first question.......is the brake master cylinder the same on a 4wd Burb as a 4wd 1/2t truck? From what I can tell it is but want to make sure before I order one....
1936 Chevrolet 1/2t
1964 Chevrolet C10
1964 Chevrolet C10 (sons)
1965 Chevrolet K10 Suburban
1969 Chevrolet C10
1937 Plymouth P4
KJSR is offline   Reply With Quote
Old 07-21-2020, 12:38 PM   #2
Southcity
Southcity's Avatar
Re: Our 1965 K10 Suburban Project
I could not say for certain they are the same but one option would be to pull the original and match it up with a new one at your go-to local parts store or, try to match it up online as best as you can. Have you tried checking on Rock Auto yet? btw - great looking K10!
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 07-21-2020, 04:47 PM   #3
KJSR
KJSR's Avatar
It's crazy....I use the Rockauto catalog quite a bit. They list nothing for brakes on a K10 Suburban. I will remove i and figure out the bore. The rest looks the same....
Thanks!
1936 Chevrolet 1/2t
1964 Chevrolet C10
1969 Chevrolet C10
1937 Plymouth P4
Old 07-22-2020, 12:03 AM   #4
Captainfab
60-66 Nut
Most everything from the B pillars forward on a Suburban and Panel is the same as a truck. Just a few minor differences. The master cylinder should be the same as a truck. While you are changing the master, I would suggest changing it for a '67-'70 master with a dual reservoir. You will have to run one new hardline but it will be safer.
Old 07-22-2020, 08:24 AM   #5
KJSR
KJSR's Avatar
Thanks Captainfab!
1936 Chevrolet 1/2t
1964 Chevrolet C10
1969 Chevrolet C10
1937 Plymouth P4
Old 08-05-2020, 02:13 PM   #6
KJSR
KJSR's Avatar
1936 Chevrolet 1/2t
1964 Chevrolet C10
1969 Chevrolet C10
1937 Plymouth P4
Old 08-05-2020, 02:35 PM   #7
scootermcrad
Super cool!!
scootermcrad.blogspot.com
scootermcrad is offline   Reply With Quote
