![]() ![]() ![]() Join Date: Jan 2018
Grille support panel and radiator core supports
The grille support panel has no areas that are rusted through, but unfortunately, the truck it was on must have been in a wreck. The driver's side, bottom corner has been pushed in a bit. I'm not an experienced bodyman, so I decided not to try to straighten it out. If you would like to try to straighten it out, come pick it up for $20.
I have 2 radiator core supports that both need repairs on the bottom. I was planning on repairing one of them, but decided to just buy a new one since my rust repair skills were not quite up to the task at the time. The first one (which I don't have pictures of at the moment) is $20. The second one has been pushed in some on the driver's side, so it's $10. Both are available for pickup only. Thanks for looking!
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 350, Saginaw 4 speed "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Re: Grille support panel and radiator core supports
Sold the $20 one, still have the $10 one and the grille support panel
| Bookmarks |
