Old 07-21-2020, 11:54 PM   #1
Keith6987
Front hub dials
Anyone know of a way to restore the blue color without painting.
Keith6987 is offline   Reply With Quote
Old 07-22-2020, 04:56 PM   #2
SeventyOne
Re: Front hub dials
I would assume the white is a combination of oxidation and sun bleaching. I wonder if some sort of polish could remove the oxidation. Sun bleaching might be a harder one to combat.
Some quick googling led me to this: https://www.youtube.com/watch?v=Fwk_fNEeH6Q
SeventyOne is offline   Reply With Quote
Old 07-22-2020, 05:06 PM   #3
harrisoncole4
harrisoncole4's Avatar
Re: Front hub dials
From what i have seen, painting seems to be the best way to go. IronCanine seemed to get excellent results painting his to the factor red on the 69s
1969 K5 Blazer - 507 Light Blue - http://67-72chevytrucks.com/vboard/s...d.php?t=802858
harrisoncole4 is offline   Reply With Quote
Old 07-22-2020, 05:20 PM   #4
Ironhorse
Ironhorse's Avatar
Re: Front hub dials
Just thinking that rather than to paint the dials believe would have better results if used a plastic dye similar to when changing colors on vinyl. Paint would have a tendency to flake off I think. With the dye process believe the coloring would penetrate deeper into the plastic instead of remaining on the surface like paint. Dying vinyl or plastic usually calls for an adhesion promoter after a good cleaning. Just some thoughts, good luck.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
