07-22-2020, 06:03 PM | #1 |
Vacuum advance fail
Doing a tune up on the ol’ rust bucket and when testing the vacuum advance unit I found it to be nfg. This is an old points type, I have the new unit and have questions regarding its replacement. How do you get the bloody thing out of there? Does the point plate have to be removed? And if so are we talking about a complete disassembly of the distributor? Perhaps it should go to a pro?
Thanks for the help gentlemen!
Regards Steve |
07-22-2020, 06:21 PM | #2 | |
Re: Vacuum advance fail
72 C10 lwb fleetside -stock 350/350 combo |
07-22-2020, 07:00 PM | #3 |
I have the distributor on the bench at this point and wear items are removed. I can rotate (carefully) the point plate against spring pressure to remove the two screws, but there is insufficient clearance to remove the 90 degree pin that inserts into the point plate from the vacuum advance can.
Regards Steve |
07-22-2020, 07:14 PM | #4 |
Who Changed This?
You have the screws out, just rotate the breaker plate so that the flange of the advance clears the body of the distributor, then push the pin down with a screwdriver or something, if needs be. It'll go.
07-22-2020, 07:32 PM | #5 |
Let me give that a try! I was attempting to not stress the point plate too much.
Regards Steve |
07-22-2020, 10:22 PM | #6 |
Try the fully adjustable unit from Pertronix. It gives you some working room for 87 octane fuel.
