12-13-2003, 05:59 PM | #1 |
computer illiterate
door glass
how in the world do you get the glass out? anyone have good directions on removing the door glass and regulator
thanks keith
72 2wd blazer 72 swb 4x4 |
12-13-2003, 06:07 PM | #2 |
i just undid all the hardware for the glass including the vent window guide. then i unhooked the glass from the regulator and took the regulator out of the hole in the door. now the glass is setting "free" inside the door. i turned it sideways and "coersed" it straight up. the metal guide on the end is a little tricky but just be patient and gently work it out. GOOD LUCK!
no longer have a ride, but still a fan! |
12-13-2003, 07:50 PM | #3 |
I am a Referee of life.
0)remove window crank and door handle
1) remove the door panel 2) remove three screws on front edge of door that go into the wing window assembly 3)remove screws in lower door that hold bottom of window rail at front 4)remove screws in lower door that hold rear window rail 5)rotate wing window sideways and work it out of the door by pulling it up thru the window slot in the door. 6)work window rollers out of slots in track 7) bring window out of top of door slot or let it down gently to bottom of door 8) I recomend removing it to work on window regulator ect. Maybe someone will post the thread that goes into more detail on this.It has been a while since I've done one.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
12-14-2003, 05:24 PM | #4 |
computer illiterate
thanks for the replies panel deland i tried to pull the wing window out a little but it looked as if the frame was coming apart so i quit and ill tell yah what i couldnt get #6 done if my life depended on it lol...... so now i am taking a break because i was about to put the BFH to it so i guess ill hit it again monday lol...........
