07-23-2020, 02:00 PM | #1 |
Header install help
I was trying to install some Jegs brand long tube headers (not my first choice, but its what i got at the moment) on my 69 sbc 307 and ran into the problem around the z bar. Passenger side went in pretty easy (just had to remove the starter to get it in there) but the drivers side wont sit down b/c of the original clutch linkage. I've read in other posts that folks have had to make several mods to the z bar and bar to make it work. I am trying to understand how i do that without destroying the linkage and making my clutch inoperable.
Or do I dimple the header as another option? trying to do what would be least path of resistance at this point until i can get some really good headers. |
07-23-2020, 02:12 PM | #2 |
Re: Header install help
Its the wrong set of headers
I have two sets one hooker the other headman both are for manual transmission c/k 67 72 trucks They design the header around the zbar clearance for a true bolt in fitment I would see if you could dimple the header tube before zbar changes they dont make a new zbar but they do make new headers |
07-23-2020, 02:23 PM | #3 |
Personally i would sell that set and post up wanted ad on cl and other facebook etc for 67 72 headers
Or just sell to offset cost of new headers I did the homemsde zbar route with a six cylinder install was not satisfied with it and it took many attempts to fit in working form Summit has them for 250 for the headman set https://www.summitracing.com/parts/h...del/c10-pickup Last edited by gmc684x4; 07-23-2020 at 02:28 PM. |
07-23-2020, 02:25 PM | #4 |
Post Whore
What gmc684x4 said. Header dimples won't hurt anything. Where as tweaked clutch linkage is likely going to cause problems down the road. There is a lot more torque on the clutch linkages than you would think.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
07-23-2020, 02:53 PM | #5 |
Thanks Guys! I may just have to go that route, i really dont want to mess with original stuff where possible - it works fine as is and really dont want to mess up the linkage.
I guess im lanking them suckers out and ordering some new ones. |
07-23-2020, 02:58 PM | #6 |
gmc684x4 that link you posted for summit. those headers will actually bolt right now to my 69 sbc with manual trans? Trying to avoid time delays and head aches with returns, etc.
Much appreciate your help! |
07-23-2020, 03:30 PM | #7 |
funny summit s list that part number as fitting and hedman list it as no to manual transmission I will go look at what part number my set has
07-23-2020, 04:05 PM | #8 |
My headers are # 69230 happy I found them I thought I sold them with a project truck
I have ran this set more then 15 years still in good shape had them about 25 years now https://www.hedman.com/product-detail/69230 https://www.summitracing.com/parts/hed-69230 |
07-23-2020, 04:12 PM | #9 |
Pays to double check the first pair I found on summit claimed to fit i re looked at hedmans site says no that set may be more for a 73 87 truck where the Zbar is in a different location
07-23-2020, 06:23 PM | #10 |
i appreciate it man. thats the same thing i did and now im hosed with a pair that i cant use. maybe ill get lucky and someone will want to buy them. Its funny that summit still tells me that 69230 does not fit my 69 c10 307 with manual trans. I really hope their indexing is just wrong. Will order them next month.
I just realized that these are for 4WD. I have the RWD base, not sure these will actually work. hmmm... |
07-23-2020, 07:26 PM | #11 |
Try Hedman tech line Tech Line 562.921.0404 M-F 8-4:30 PT
I am planning on reusing mine back on my 68 after I re convert it back to a 2 wheel drive I have dug up a straight c20 chassis and a c10 chassis that has a cut frame |
07-24-2020, 01:18 PM | #12 |
Thanks gmc684x4! I gave them a call and they confirmed that I should be looking at the hedman headers part# 69092. Should have just called them in the first place and purchased these way back when...the more you know i guess.
07-24-2020, 01:31 PM | #13 |
Lots say 67 87 but that is for automatic trucks
