Old 07-23-2020, 04:07 PM   #1
Andy4639
Old member
Andy4639's Avatar
Question City/Hiway
Does anybody know what the setting's mean for the under dash AC unit's.
Mine has the setting's...City/Hiway and I'm trying to figure out what they are and what is the difference between them. Surely somebody on here knows what they mean and how to use them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 07-23-2020, 05:53 PM   #2
roboticjunky
Re: City/Hiway
This is what I found on another site.
Some of the instructions for the user are interesting in light of today’s technology. For instance, all units offered “city” or “hiway” knob positions. We think the “city” position was what we know today as “recirculate,” which cuts off the outside airflow. Regardless of model, the instructions provide some version of “Turn the air control [fan] to the desired setting, then adjust temperature control to coldest “City” setting if maximum cooling is needed.” Sounds just like what we do in today’s cars, non?
After switching to the “hiway” position, operators were reminded that “At prolonged high speeds, the compressor capacity is normally more than is needed and ice may form on the evaporator coil. Icing is readily noticed by a marked decrease in air velocity. To overcome this condition, turn the temperature control to the off position. As soon as the coil is clear and normal air delivery is restored, adjust the temperature control to the ‘hiway’ position.”
roboticjunky is offline   Reply With Quote
Old 07-23-2020, 11:03 PM   #3
Andy4639
Old member
Andy4639's Avatar
Question Re: City/Hiway
That's what I assumed but how does a under dash unit cut off the outside air coming into the truck when there is nothing hooked up to the truck t do this?
I'm thinking since this unit is a AC/Heater you would turn the knob to let warm water into the evaporator to de-ice it maybe?
Old 07-24-2020, 07:28 PM   #4
Re: City/Hiway
Which would I use on the Baltimore Beltway (I-695) or I-95 through Baltimore? Both?
