Old 07-24-2020, 01:10 AM   #1
AllGoNoShow
Fixing non-working windshield wipers....
Going to get into fixing the windshield wipers that haven't worked since I bought my 1968 C10 a couple months ago. Looked at a few past threads and I figure I have a plan of attack on troubleshooting it but I have two questions-
1. Should a 68 have a one or two speed wipers? Or were both options?
2. Do I have to remove anything under the dash to get to the motor and the wiring attached to it?
Thanks for the help!
AllGoNoShow is offline   Reply With Quote
Old 07-24-2020, 08:14 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Fixing non-working windshield wipers....
1. They are two speed wipers with non-depressed park.
2 . Maybe if you have A/C, otherwise you shouldn't have to remove anything under the dash. You will have to remove the wiper blades & cowl vent to remove the clip on the wiper arm.
http://67-72chevytrucks.com/vboard/s...d.php?t=413551
LockDoc
Leon
Old 07-24-2020, 08:17 AM   #3
cj847
cj847's Avatar
Check the simple stuff first. Fuses, etc. Next i would check that your switch is getting good ground to the dash. NOTE> the wipers are always powered and when you turn the switch it provides the ground.
In my experience the problem is usually not the motor.
cj847 is offline   Reply With Quote
Old 07-24-2020, 08:24 AM   #4
BigBird05
With the key on check for power at the motor. If you have power then ground the out the ground wire at the motor. If the motor works, ground out the the ground wire at the switch. If the motor works check to see if the switch has a ground.
BigBird05 is offline   Reply With Quote
Old 07-24-2020, 08:46 AM   #5
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I'd invest in one of these, https://www.classicparts.com/1968-Sh...ctinfo/04-026/ My 72 manual says if the parking brake assembly is located on the vertical surface of the cowl front panel, (directly below the wiper motor) you must remove the parking brake assembly attaching bolts (4) to allow shifting of the assembly rearwards to allow access for removal of the wiper motor. You can use a cotter pin removal tool or a large dental pic with a 90 degree bend on the end to reach through the cowling to remove the wiper motor drive rod retainer, the wiper drive rods slip off the shaft. The left defroster vent duct will have to move, it's a slip fit. Disconnect the washer hoses and electrical connections, then remove the motor...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 07-27-2020, 03:47 AM   #6
AllGoNoShow
I got lucky. Fuse holder (not even the actual fuse) was corroded and covered in Arizona dirt/sand. Cleaned it up and boom it works. I will say I don’t notice any discernible difference between low and high speed (tested on a dry windshield), but that seems to be a common complaint with these trucks.
Old 07-28-2020, 12:19 AM   #7
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Nice. If I remember right there only a small variance in my C10. My C20 the same, but it's a bit tired and sometimes needs a boost just to get started to begin with
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-28-2020, 01:37 AM   #8
custom10nut
custom10nut's Avatar
Yeah there’s a couple “weaknesses on these wiper setups. One Is there’s not much difference in the two speeds, The other is getting and keeping the washer pumping, so it will spray onto the windshield.
Fix 1: there’s a vendor that makes a delay switch that can be hooked into the stock switch.
Fix 2: put an upgraded pump from an S-10 in (there’s many threads on this)
Or Fix 3:“Force Prime” the pump and run washer tubing up the underside of the wipers to get a better spray.
I did the the #3 and it works quite well
custom10nut is offline   Reply With Quote
Old 07-28-2020, 07:52 AM   #9
72supr
Glad you got it going.Try some penetrating oil on the linkage under the cowl.That can make quite the difference on the wiper speed.
72supr is offline   Reply With Quote
