Old 07-24-2020, 09:24 AM   #1
kglowacky
shifter indicator
have a 78 and put a 83 tilt column it it. cant figure out how the dash shifter indicator that shows what gear your are in hooks up. some sort of wire operates it. a picture would sure help
kglowacky is online now   Reply With Quote
Old 07-24-2020, 09:33 AM   #2
MJN
MJN's Avatar
Re: shifter indicator
This is a shift indicator from a '74, the metal tab attaches to the column with the screw. There should be a collar on the column that rotates with the shift handle- thats what this attaches to.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 07-24-2020, 10:27 AM   #3
sweetk30
sweetk30's Avatar
end of the cable with metal tab and screw . clips over the plastic body that moves with the shifter . the screw holds it in place on the early unis . in the 80's they quit doing the screw .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 07-24-2020, 01:09 PM   #4
Axle
Axle's Avatar
fwiw my 83 still had the screw. That said, the plastic where it attaches gets brittle and can break off, which it did on my 83. May have occured to your tilt column if there is no obvious slot for the clip & screw.
Axle is offline   Reply With Quote
Old 07-24-2020, 01:14 PM   #5
kglowacky
I assume the round plastic collar is where it attaches. My collar keeps coming loose when i move the shifter lever. is there suppose to be a slot in the collar. Mine has none.
Old 07-24-2020, 04:20 PM   #6
Wgesnerjr
Wgesnerjr's Avatar
some later model shift indicators just clip on the collar of the steering column. no screw needed. you adjust the indicator by where it clips to the collar.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 07-24-2020, 04:34 PM   #7
69Tom
69Tom's Avatar
If anyone needs one. It's not the correct lettering for 73-74, but is the same design.
https://www.cheyennepickup.com/colle...ift-indicators
69Tom is offline   Reply With Quote
