07-25-2020, 01:16 PM | #1 |
396 experts need help
Hey Guys,
I rebuilt my 396 which is a 69 block. Have the Camaro Heads with a Melling MT6 RV Cam. I ended up Putting Poly locks as the replacement Rocker nuts kept coming loose. Factory ones stayed tight. It has 20-50 oil with Zinc additive and 50 PSI oil pressure at idle with a mechanics oil gauge hooked up. Sounds great when cold. Once it hits 185 - 190 degrees , it idles a little rough and sounds like lifters clacking. Done valve adjustment 10 times. I used 3/4 turn. Tried 3 different oils........ If I missed one of the oil plugs for lifter galley on front of motor behind the timing gear , Would I still have 50 psi ? (Doubt it !) . Plugs are staying white so I am thinking it is also lean. Compression is 150 psi all 8 cylinders.......... What else ? Almost ready to yank it and build another motor. I pulled the Bypass valve this morning and it seems good. No gasket although I do not think that would change much other than possibly mixing a tiny bit of unfiltered oil with filtered oil ? |
07-25-2020, 01:29 PM | #2 |
Re: 396 experts need help
Why such a thick oil ?
Most guys i know run 10/40 or even 5/30 20/50 is a diesel truck oil Do you have headers? Are they loose Have you used comp cam lifters i have heard there fairly noisy |
07-25-2020, 01:35 PM | #3 | |
I have cast manifolds and yes I hear a slight exhaust leak which I am going to address this weekend. But that should not make it idle rough as the noise increases or am I wrong ? Bolts are very tight. Standard melling brand Hydraulic lifters. Started with a chinese brand which I swapped already as at first a few would not pump up. |
07-25-2020, 01:50 PM | #4 |
Is your 50 psi idle oil pressure reading with the engine and operating temperature or cold? What is the oil pressure hot at cruise rpm?
Steve weim55 Colorado |
07-25-2020, 01:54 PM | #5 |
Have you tried 10/40 ?
Did you check for coil bind on the valves? |
07-25-2020, 02:04 PM | #6 | |
When you changed lifters did you try to break the cam/lifters in again. Sounds a lot like a cam getting wiped. Big blocks are notorious for wiped cams. |
07-25-2020, 02:35 PM | #7 | |
It is 50 psi weather cold or hot . So cal has not been to cold in the mornings lately. It will go up to 55-65 depending on speed. |
07-25-2020, 02:36 PM | #8 |
When I removed the lifters the cam looked fine. Also it is not noisy until you drive it and it warms up . When it got to 25psi It was even noisier.
07-25-2020, 03:04 PM | #9 |
Of course the cam looked fine. Lifters and cam wear in togethor.
Changing the lifters likely changed that. Pop the valve covers off and check all the rockers are moving the same. |
07-25-2020, 03:15 PM | #10 |
Ok . I will look when the motor is hot to see if I can spot the change. I cut window in a pair of valve covers for purposes of valve adjustment.
07-25-2020, 03:33 PM | #11 |
Did you have machinist check valves for your cam lift for binding issues ?
07-25-2020, 03:50 PM | #12 |
07-25-2020, 04:03 PM | #13 |
That is a big check mark of not an issue valve binding can wipe the cam as well
Did the machinist check the new spring rates match the cam too heavy a spring can be hard on the cam too |
07-27-2020, 08:35 AM | #14 |
Post Whore
I'm a bit confused on the time line of events. You rebuilt the motor with Chinese lifters and then you couldn't get them to pump up and so you replaced them.
Was that before you fired the engine for the first time and broke the cam in? When you said they wouldn't pump up what exactly do you mean? What is the part number of the new lifters?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
07-27-2020, 10:34 AM | #15 |
When you tighten the set screw on poly locks it acks the initial adjustment off. If you tight them up without the set screw sufficiently backed off it will crack the poly lock. Poly locks on hydraulic cams are a pain in general
07-27-2020, 01:00 PM | #16 |
I would just verify your procedure for adjusting the valve lash is correct.
An easy way to do it quickly is mark the distributor body with a marker where each terminal is on the cap. Verify your at #1 TDC with the rotor pointing at the correct terminal. Adjust both rockers on #1 for 1/2-3/4 turn after zero lash. Remember with poly locks to go the half turn or so, back off an 1/8 of a turn and seat the set screw and then turn the rest of the way. You can mark your balancer with a mark every 90 degrees as well and run through the same procedure. Then repeat going through the firing order using your distributor body as reference.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" Last edited by j_cst_10; 07-27-2020 at 01:07 PM. |
07-30-2020, 10:34 AM | #17 | |
07-30-2020, 10:48 AM | #18 | |
When I say they would not pump up , I mean you remove valve cover while motor is warm and you are able to lift the rocker arm on the valve with the bad lifter and collapse the plunger. New ones all pop up except what I notice now in the morning after the motor ran last making the noise, the lifters (Not sure how many) are loose and tap for 20 seconds or so. So I think the lifters are not getting enough oil. I really believe this . |
07-30-2020, 11:37 AM | #19 |
Did you re break in the new lifters after you changed them ?
07-30-2020, 11:38 AM | #20 |
I would adjust using the procedure I outlined so you know exactly where they are. Move the pushrod up and down and tighten until you feel zero lash. Then 1/2-1 turn after.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
07-30-2020, 11:48 AM | #21 |
laying low
That sounds an awful lot like the lifter issue the early 454's had. After warm up lifter clack appeared and this was with a stock engine. Oil pressure was good but it clacked after warm up. Usually it was on cylinder #1. The GM fix was to drill a small hole in the lifter galley plug at the front of the block next to #1 cylinder to let the hot oil out and fresh oil into the lifters. Dad and I drilled his to cure his lifter clack after having replaced those lifters several times. No more problems. There was a service bulletin back then so this information came from GM in the early 70's.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
07-30-2020, 11:50 AM | #22 |
I have the same issue with my 454 with the nuts not holding adjustment and slowly backing off. I just bought a new set of nuts and will swap them out and adjust this weekend. I think the ones that came with the rockers may be junk chinese who knows. I have the comp cams roller tip rocker set
07-30-2020, 02:15 PM | #23 |
I wish I could give you some sound advice but honestly it’s so difficult to discern these issues without actually being in front of the engine and hearing it. I can tell you what my recent experience is although it’s a bit discouraging. I will no longer do any engine rebuilds for customers anymore. I have done More small and big block Chevy’s then I can count for decades prior without issue but in the last five years replacement parts in the supply chain have become so bad and unreliable I can no longer put together an engine I can stand behind because of it. I can think of 4 engines in the last five years I have had a hand in that have the exact problem you are speaking of. Noisy lifters when the engine is hot. In my personal opinion I really believe it is defective lifters in every case but I do not have definitive proof.
08-01-2020, 04:40 PM | #24 | |
The chinese and taiwan parts are total Garbage. That is correct. |
08-02-2020, 08:31 AM | #25 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
This! And I'll add checking with your eyeball is a crude method, use a dial indicator to measure the lift! Only then can you rest assured that all lobes are good, it only takes one bad lifter to wipe out it's lobe. I've had out of the box lifters that failed to pump up because they were failing to collapse presenting zero preload! The Asian machining processes are questionable at best and should never be trusted!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
