What ignition switch wire for electric fan?
I'm installing an electric fan on my 66.Directions say for the yellow wire to go to the ignition switch.There is four whores behind the switch.A brown purple pink and dark pink.What one is the best to use? Thanks.IMG_20200725_160438.jpgIMG_20200725_160326.jpg
![]() Join Date: Jan 2011
Re: What ignition switch wire for electric fan?
Here is what I would do. Look at your fuse box and find one of the accessory terminals that becomes hot when the ignition is on. Pick up your hot from that to activate the relay. Thats what I have done to power my convertor lock up controller for the 700R4.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Moderator
![]() ![]() Join Date: Aug 2011
He's right. You dont want to power the fan through the ignition switch.
Wired it up to the fuse block and it works as it should.Thank you.
