![]() Join Date: Nov 2014
Converting High back bucket seats to low back
Has anyone converted High back bucket seats to low back? Here’s a picture of what I have.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Converting High back bucket seats to low back
Maybe?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland
There is a guy who bought a few highbacks from me. He cuts the top off and recovers in 70-72 covers and asks $1200 I could use some plaid material if you discard
Posted via Mobile Device |
I took some seats to an upholstery shop asking about the same thing...to cut the back of them down to my glass height, shape the top and make them look right. The shop didn't want to touch it. Guy explained in detail about how cutting the seats down wasn't as straightforward as I thought it would be...that he would have to build new structure into it once existing structure was cut away... It worked...I chose not to pursue cutting the seats! Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
![]() Join Date: Jul 2008
I have also been thinking about the same thing... cutting a high back down since they seem to easy to locate or even try looking for a 73-77 blazer/truck seats. curious if its been done and if it is worth it.
1965 c/10 swb 1969 c/10 lwb
Post Whore
![]() ![]() Join Date: Sep 2008
I've never cut any, but this prompted me to think a little. I have a set of 69/72 seats I let sit in a cab for years and the weather was not kind to the lower frames.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
![]() Join Date: Sep 2016
Foams fit good, skirts are different.
Post Whore
So is that hoop at the top the only difference in the back?
x2?
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
x3
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
Pretty much the same. The high backs don't have the round bar tacked in the back or the slotted holes around inside perimeter of the back. easy fix.
I'm going to try to recover both low and high/converted to low. I will post up the difference. |
Thanks & please do post info as you move forward. Curious to see what differences there were on the GM products.
#13 |
The buckets in the first post are from a blazer correct? Not a van?
#14 |
Driver’s seat has tracks allowing front to rear adjustment while passenger side flips forward so I’m thinking Blazer.
#15 |
![]() Join Date: Dec 2014
Checking to see if OP or anyone else has done a successful conversion from hi back to low. I have a set of hi backs that I can't give away, I am willing to cut them down if there is any chance that it will be successful, but I want to do my due diligence.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
#16 |
Just a note folks! Hope that you don't get smacked in the rear after you cut the seats down. I got nailed good and after I woke up with damaged neck and shoulder muscles to this day 16 years later, I swore that with technology today that if I ever did anything with the seats it would have to include restraint protection. High seats or headrests are a must. My two cents worth as it is all I got left cause I own a truck. Have a good one eh.
#18 |
![]() ![]() Join Date: Apr 2022
I am in the middle of doing this myself. I forgot to take pics of the test fitting the foam, but the 71/72 style foam fits perfectly. I still need to drill the holes for the hog rings on the back side. I am currently making adaptor risers for the tracks as I want the seats a little lower than stock mounts. I am also too cheap to buy factory bucket seat tracks and my truck is a 68. I got a set of tracks for a 66-67 Chevelle buckets for cheap and I am making those work in my cab to save my bench seat mounts and limit how many new holes I need to drill through the floor.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
#19 | |
#20 |
yep I have been running around the PNW since I got the truck done, gonna do it again this summer as well once I get these bucket seats into the truck.
| Bookmarks |
