Old 07-26-2020, 02:06 PM   #1
richards72chevy
richards72chevy's Avatar
Rear light/signal questions.
I think have the bigger plugged figure out for my tail lights and signals.What is this smaller plug for?Is it a ground? Also I'm going to be putting in a signal switch that just mounts to the steering column.Will I still be able to keep this flasher if use one of them signal switches that mount to the column?IMG_20200726_124903.jpgIMG_20200726_124521.jpg
richards72chevy is offline   Reply With Quote
Old 07-27-2020, 09:26 AM   #2
Superduke
Re: Rear light/signal questions.
I think that single wire plug goes to the fuel gauge.
Superduke is offline   Reply With Quote
Old 07-27-2020, 02:31 PM   #3
cwcarpenter98
cwcarpenter98's Avatar
That smaller wire could be for reverse lights. Why not use a factory turn signal switch?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 07-27-2020, 03:30 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
On the original rear harness of my truck, the smaller connector was for the license plate light.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-28-2020, 07:12 AM   #5
richards72chevy
I don't know if there ever was tank back there.May be an auxiliary tank could have been added.The truck does have a utility bed on it.But this looks like the factory plug.
Old 07-28-2020, 07:19 AM   #6
richards72chevy
I'm not for sure what direction I'm going with the column yet.I may add power steering later on and if I do I'm going to upgrade to a later c10 column with a collapsible shaft.From what I have read on here the switch and cancelling cam on the 60-66 c10 is a problem area.
Old 07-28-2020, 07:23 AM   #7
richards72chevy
I didn't even think about that I will have to check it out.I thought it could have been a ground because the test light seamed brighter when I grounded that plug to the frame.
Old 07-30-2020, 09:17 PM   #8
Brim
Brim's Avatar
Second that, that's how my 64 is.
Mark
Brim is offline   Reply With Quote
