Old 07-26-2020, 05:59 PM   #1
Pontitruck
Pontitruck's Avatar
First Fire, No Throttle Pedal Actuation
Hey guys, it’s been awhile and I finally fired the 65 GMC up yesterday. It started no problem and it idled but I have no throttle pedal and P0120 and P2135 codes. Since the TAC module is under the seat with the computer and the pedal is loosely mounted I’m assuming I need to ground both of these. The interior is painted so do I need to run ground wires and or mount them to bare metal?
I have not checked but will later to see if there is a 5 volt reference at the TB.
The harness is BP and the rest of the set up is 2005 DBW.
Any other tips or testing?
Thanks!
Joe
Pontitruck is offline   Reply With Quote
Old 07-26-2020, 10:05 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: First Fire, No Throttle Pedal Actuation
I like to use the external or internal tooth washers on all my ground points...I put the against the paint and the ring terminals on top..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-26-2020, 10:54 PM   #3
Pontitruck
Pontitruck's Avatar
Originally Posted by mongocanfly View Post
I like to use the external or internal tooth washers on all my ground points...I put the against the paint and the ring terminalson on top..
I use those too. Any input to the TAC ground question? Thanks
Old 07-27-2020, 01:07 AM   #4
mongocanfly
Post Whore
I don't know...you could rig up some temp ground wires and see if it helps...I know you cant ever have to many grounds on a LS setup...I'm doing my 1st dbw LS now.....all my others were dbc
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 07-27-2020, 09:02 AM   #5
bigmoe
bigmoe's Avatar
Does your pedal match your Tac? I tried to use a car pedal with a truck Ecm (Gen IV) and also got idle with no throttle up. It looks like both those codes are TPS related and maybe are pedal wiring related? Car and truck pedals can be interchanged by swapping two wires at the pedal plug.
bigmoe is offline   Reply With Quote
Old 07-27-2020, 09:40 AM   #6
Pontitruck
Pontitruck's Avatar
Well, the pedal came with the project but I didn’t get the TAC so I bought one for the same your as the drivetrain and ECM. How do I know if they are mismatched?
Old 07-27-2020, 11:13 AM   #7
bigmoe
bigmoe's Avatar
I had mounted a mystery pedal but I knew my Ecm was truck (gen IV doesn't have a tac) so I got a truck pedal from the wrecker and just mounted it to a piece of plywood, plugged it in and it worked fine. Once I knew my mounted pedal was a car pedal I found out on this forum which two wires needed to be swapped at the plug. If you can you should try to find out more if your tac and pedal are truck or car.
Old 07-27-2020, 01:30 PM   #8
bigmoe
bigmoe's Avatar
Here is my (car) pedal. The guy I got my engine and harness from had it pulled from a Tahoe by his hot rodder sons but he had no clue where the pedal came from. Some kind of car. The truck pedals are plastic and curvy and don't retrofit well.
Old 07-27-2020, 09:44 PM   #9
Pontitruck
Pontitruck's Avatar
SThis project came with a pedal, which now I see is from Psi conversions where the harness came from. I did not get a TAC module so I chose one that said it fit what the drivetrain was out of. It’s an 05 5.3 and 4l60eor at least I thought I did.
I’m going to call Psi tomorrow to see if they will tell me what module goes with their pedal which is different than Bigmoes above.
Old 07-27-2020, 10:51 PM   #10
ls1nova71
ls1nova71's Avatar
You don't need ground the TAC or pedal. It does seem like maybe you don't have the correct TAC. It should have a part number on it that will tell what year its for. Does the throttle body move at all when the key is first turned on? You should hear a slight click when the key is turned on, doesn't need to be started, but that will tell you if you are getting power to the TAC.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 07-28-2020, 07:50 AM   #11
Pontitruck
Pontitruck's Avatar
Thanks Nova, I will check. I do have 5 bolts everywhere so that’s encouraging. Going by the pic below I found while searching, I have the right TAC (8923) for the style of pedal but it could be defective.
Old 07-29-2020, 09:05 PM   #12
Pontitruck
Pontitruck's Avatar
TB cycles with the key.
Old 08-02-2020, 10:12 PM   #13
aknovaman
Attach the HPT file from the PCM.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 08-03-2020, 12:56 PM   #14
Pontitruck
Pontitruck's Avatar
[QUOTE=aknovaman;8786162]Attach the HPT file from the PCM.[/QUOTE
I sent it out and had it done, don’t have a file unfortunately.
Old 08-03-2020, 01:05 PM   #15
aknovaman
check your pm.
FMCDH GBU and GBA
Old 08-05-2020, 07:27 PM   #16
Pontitruck
Pontitruck's Avatar
She’s alive, needed a throttle body. The other would cycle but that was it. No codes and the fans even come on when they’re supposed to. I’m psyched. Now to figure out how to hook up that darn neutral safety switch at the trans.
Old 08-06-2020, 07:26 AM   #17
AussieinNC
Moderator
AussieinNC's Avatar
What transmission is in the truck?
If its an auto trans, there should be a factory NSS and reversing light switch on the side of the trans on the shift rod....(assuming you used a truck trans)
let us know what trans is in the truck.
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 08-06-2020, 12:44 PM   #18
Pontitruck
Pontitruck's Avatar
Correct, it is a 4l60e with a range selector, the two harness type
Old 08-07-2020, 01:41 AM   #19
ls1nova71
ls1nova71's Avatar
Do a search on here, I have posted how to wire the NSS up several times in the past.
Old 08-07-2020, 08:01 AM   #20
Pontitruck
Pontitruck's Avatar
Thanks Nova, I have all of your information.
Old 08-11-2020, 06:34 PM   #21
Pontitruck
Pontitruck's Avatar
Wink Re: First Fire, No Throttle Pedal Actuation
Nova,
On your hand written schematic you have the wires numbered coming out of the range sensor as 1, 10, 11, and 12. How do it correlate that to the Circuit numbers on the harness? I have the old 2 wire style range sensor. Example, lt green is backup lamp supply voltage and is numbered circuit #24. I believe I only need to use Pins A, D, G, and E correct?
I hope that makes sense lol
Old 08-11-2020, 11:10 PM   #22
ls1nova71
ls1nova71's Avatar
Here you go, just replace the numbers with the letters as follows, 1-G, 10-F, 11-C, and 12-E. Hope this helps.
Old 08-12-2020, 07:18 AM   #23
Pontitruck
Pontitruck's Avatar
Perfect! Thanks
