Old 07-28-2020, 01:36 AM   #1
Lokin4AReason
Lokin4AReason's Avatar
Working on the brake(s) ( as in the front )
Hello all
I am just wanting to get some insight or feedback on at hownto tackle this . I have drum(s) all around and want to convert my front drum(s) to disc . Well my question would be ;
What year c10 spindle(s) should i consider in keeping my 6lug stock wheel(s) ( dont want drop it ) and the clearing the caliper(s) the stock wheel ?
Or
What aftermarket brand(s) are preferable in sourcing out option(s) on having this done ?
Thanks for the helping and looking . . .
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is online now   Reply With Quote
Old 07-28-2020, 08:54 AM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Working on the brake(s) ( as in the front )
If just changing spindles and keeping your factory control arms, you can use either 71-72 spindles with 71-72 ball joints or use 73-87 spindles using the 73-87 ball joints. If going with the squarebody stuff, grab the 1-1/4" spindles and rotors instead of the 1". The 1" started some time in the early 80s I think.
For wheels, if you swap to 5 lug, any 5 lug truck wheel is made for disc brakes. If going with 6 lug, you could run any 71-87 stock, 4wd wheel (steelies or truck rallies) or go with some aftermarket Wheel Vintiques steelies. I'm going to run a set of 15x8 Wheel Vintiques steelies so I can run original hubcaps
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 07-28-2020, 09:22 PM   #3
PGSigns
PGSigns's Avatar
Summit racing has had the best price on the 6 lug rotors for use on 73 to 87 spindles. You need a spindle donor using 1 1/4 rotors. There is a ball joint swap and some tie rod changes to do but doable.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-28-2020, 09:37 PM   #4
DPowers
DPowers's Avatar
FAQs Section may help.
http://67-72chevytrucks.com/vboard/s....php?p=4450757
DPowers is offline   Reply With Quote
Old 07-30-2020, 11:47 AM   #5
Chevy Fleetside
Chevy Fleetside's Avatar
Here is another way to do it. http://www.67-72chevytrucks.com/vboa...isc+brake+swap
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-31-2020, 12:27 AM   #6
Lokin4AReason
How hard is it to find oem stuff ( as in 71 or 72 spindles ) ?
Old 07-31-2020, 12:34 AM   #7
Lokin4AReason
As in the 6 lug setup ?
Old 08-01-2020, 12:03 AM   #8
cwcarpenter98
There were not any factory 6 lug disc brake stuff. It's real easy to find stock spindles because so many people put drop spindles on. You can run the aftermarket 6 lug 1-1/4" discs on stock 1-1/4" spindles. I believe the 71-72 spindles were 1-1/4", but if I'm wrong, I know someone will correct me
Christian Carpenter
Old 08-02-2020, 12:44 AM   #9
studeclunker
studeclunker's Avatar
Have you looked into Jim Turner's conversion kits?
studeclunker is offline   Reply With Quote
Old 08-06-2020, 04:28 PM   #10
forestb
forestb's Avatar
What year truck? Won't that make a difference?
forestb is offline   Reply With Quote
Old 08-31-2020, 12:54 AM   #11
Lokin4AReason
search jim turner on the forum or the web ?
Still on the search for the spindles . . Might to find some old yards for this
