where does this go?
Thanks for your help, it was loose in my cowl.....
![]() Join Date: May 2010
Re: where does this go?
It's the "fresh air door" used on A/C trucks. The picture below is the best I can do and, unfortunately, it's not visible in the pic. It's under the cowl on the passenger side and is attached under the hood to the vacuum reservoir as shown. Under the cowl there is supposed to be a spring (black at 2:00 position in the pic) to hold it in the open position. One end of the rod attaches to the vacuum reservoir. The other end sticks through a hole (arrow) in the firewall.
Jim Last edited by FirstOwner69; 07-29-2020 at 11:40 PM. |
20' Daredevil (Ret)
![]() Join Date: May 2003
Dunno if this drawing will help.... or not. The LMC p/n for the door is 32-0790 if anybody needs one.
Ahhh...yes it is an AC truck but is missing the vacuum piece (#5 in pic).
I have noticed a few missing pieces besides this one and have already decided to go with a vintage air rather than buying all the missing components. Thanks for the help!! |
So annoying when lazy painters get overspray on things that should not have body color...just lazy.
I am installing vintage air on the truck. Should I seam seal this part in? The VA instructions do mention closing off the inside vent but will this keep any trash out of the area?
#7 | |
20' Daredevil (Ret)
Andy has blocked his off and urges others to do the same. I'm going to quote an old post of his -- I hope it helps. If you have more questions, you can do a search for more of his posts, or you can shoot him a PM.
#8 | |
The Older Generation
Not sure why you couldn't put the stock manual vent door back on the inside, then it would be just like the drivers side.... Maybe I don't understand how the Vintage Air works. Dunno'. LockDoc
20' Daredevil (Ret)
Well, I don't know how VA works either, Leon -- just passing on what Andy said. When I worked on my A/C a few years ago, I put it all back to original condition.
#10 | |
Maybe Andy or another VA owner will pop in and explain it to us. LockDoc
I am relatively sure that all VA systems (and any other aftermarket system) are recirculate only. They are on "Max air" all the time.
I just re-read the instructions and found the answer i had overlooked previously. The current install instructions for the 67-72 is to permanently seal the kick panel vent. And to replace the cowl vent vacuum control with just a cap (ie- effectively disabling it - assuming you still have the return spring). And to seal the hole where the blower was. Other than leaking gaskets, rust holes, and opening a window that seals up all fresh air possibilities. . |
Well, if you block it off, you can certainly still get fresh air, but not conditioned fresh air. I for one like to make things work as intended. If the outside flap is not sealing, fix that and move on.
