![]() Join Date: Sep 2019
Battery Cables and Battery Relocation?
About to pull the trigger on ordering everything I need for the battery relocation.
My intention is to move the battery to the left side of the toolbox. Positive will go to a battery disconnect located on the box and then run to the engine bay across the box, through the box/bed, and up the right frame rail. Ground will run across the box, through the box/bed, and go to frame. I plan on adding a Ford starter solenoid on the firewall as well. I have not had any issues with heat soak on the starter but it makes for cleaner wiring I think. My plan is to run 1/O cable on all runs described above and I should have plenty of room for it. From the starter solenoid to the actual start solenoid I will likely reduce cable size to a 1AWG if I think routing the 1/O around the headers and such will be too difficult. Thoughts? Am I crazy to run 1/O?
Mike 1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop Obligatory Build Thread HERE! 1979 C20 RCLB - 350 - TH350 Auto |
| Bookmarks |
