Scanningr for codes
When I scan the computer where it shows ready to fire and all that, two lines show 025 and H025 not ready. Could this be a problem with the tune ( I am battling P0171 and P0174 codes) or is it something that was deleted? Also, does anyone have the part number for the vacuum port for the brake booster on a 2007 4.8. I would like to replace mine to eliminate a possible cause for my supposed vacuum leak. Thanks, Tbrown
tbrown's 56 Cameo Build |
Moderator
![]() Join Date: Jun 2017
Re: Scanningr for codes
Passenger side of intake manifold on side of top chamber is a vacuum port usually used as a blend door vacuum source....
If you dont need it, just plug it... What vacuum ports are you wanting to add? Power brakes ? ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
I am using that port for vacuum wipers. Not trying to add anything, just trying to find vacuum leak or cause for P0171 and P0174 codes. I have power brakes, and just want to make sure the swivel on the booster port isn't leaking vacuum.
tbrown's 56 Cameo Build Last edited by AussieinNC; 08-01-2020 at 12:49 PM. |
It's rare for the booster port o-ring to leak, Intake gaskets are common & the intake itself being cracked is very common on wreaking yard engines.
#5 | |
Moderator
As clinebarger said...intake gaskets and intake manifold leaks, especially under the manifold...
Already changed the intake gaskets, but will block off that port and try it. Thanks for the help.
If the O-ring is leaking.....There really isn't a way to block it with the quick release mechanism & all.
Though your booster may be leaking.....Clamp/pinch the booster line to confirm. Can you watch live Fuel Trim Data?? A vacuum leak will show as high trim corrections at idle & correct under acceleration. Normal trims at idle & positive corrections under acceleration would be a fueling issue. (MAF, Injectors, Fuel Pressure) |
That is new information to me, I will check it out. Thanks
Also make sure your pcv on the valve covers are hooked up as this will throw the codes.
Subbed for new knowledge......
![]() Join Date: Sep 2005
they do sell a plug that will go into the booster hole(used on trucks with hydro boost) spot no longger sold by gm they are a dimond in the rough if u find one everyone wants good money for them i got lucky and soeone here on the fourm sent me one since im using manaul brakes still
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
