![]() Join Date: Oct 2001
looking for some sbc heads!
I'm in need of some stock unworked 882 heads,does anyone have a set that they know are good! 29720 for shipping!
Things happen for a reason! |
in the near future i will be selling my 882 heads but they are ported and have big valves installed dont know how long you could wait or if your interested
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
![]() Join Date: Sep 2000
I have a used set off a 400
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
![]() Join Date: Apr 2003
I know that Randy (Teeitup) has pallets of used sbc heads, might try to pm him in the morning
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
I have quite a few sets of heads that have been cleaned and mag-na-fluxed ,but will need to be reworked. I'm not sure which heads are considered 882's , but if you can give me the casting #'s that will work for you, I'll check to see if I have what you need.
Mike
Romans 10:9-10 |
hehe..the "882" is the last 3 numbers of the casting numbers
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
Drive it like U stole it
Donnie I wished i knew this a week ago ,I just gave my store manager a set of 882's . Why do you want a set ? you do know that is one of the worst sets for cracking!I may have a set of 487x heads but shipping would be high.
71 custom 10 swb 72 nova ss 72 nova custom 87 s10 96 burb 94 camry 53 5 window 3100 |
I need the heads for my racecar engine,I'm running a pure street divsion car and I cant run the doublehump heads but we can shave them down and they have to be straight plug heads with no less than 70cc and 3 angle valve job,I was told that I need 882 heads can someone give me some good advise on this,I think the 882 heads would be fine!!!!!!!!!
its all about the +6 inches
882s are fine. The cracking issue is WAY over stated. Not to mention there is a light weight casting, and a heavy weight castin.
These heads are one of the better heads that are still commonly found. I hade mine up to about 260 degrees when I tossed a fan belt a couple years ago, compression test showed all to be fine, so I'll asume no damage...esp when you consider it was over 2 years in the past. Big Orange, you should be able to find a set in a local wrecking yard, one of the most common castings out of the entire decade of the 70's. |
Careful, they attack...
I had a set of heavy 882's I sold on ebay to a guy for his race car. Must be a common set for racers to use. Didn't get much for them though. I should imagine that they would be pretty common in junk yards. Good luck.
That is the hole reason for asking you guys,I'm just starting out in this racing thing and theres 3 tracks in the nearby area so the other racer's have kinda eat up all the 882 heads around here,besides most of the salvage yards around here will only sell complete engine only! There not that exspensive from what I've been told because there so plentifull but I figured it would be easier to get them through someone on the board!
Might also want to check ebay, I know they go cheap there too. I think I sold mine for less than $50, but mine were bare castings.
Also might want to check out this site and post a want ad there. They have been helpful to me for some engine parts. |
#13 |
487x heads would be better.
