Side trim hole location?
My 65 Fleetside never had side trim and I never drilled any prior to paint. I plan to 3m the trim on as I’ve seen on this forum. The trim strip was not painted on either and I plan to use a vinyl stripe between the trim. If someone could give me the vertical measurements from the crease down to the top and bottom holes I’ll run the vinyl trim width at that location. Thanks.
| Bookmarks |
