Tips For Installing Sport Mirror Banking Plate
I can’t seem to get the plate lined up properly, any suggestions ? Thanks
71 C-20 07 Magnum RT AWD |
![]() Join Date: Nov 2014
Re: Tips For Installing Sport Mirror Banking Plate
I use a small really strong magnet. Even use some duct tape. Get the forward on started to hold from falling down then on of the rear ones and your good.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
Thanks I struggled yesterday...
![]() ![]() Join Date: Feb 2009
Duct tape
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
I used a magnet, and stood outside the vehicle, window down, and my arm reaching in to help align. It wasn't easy, but the magnet helped a lot.
What I did was put 1 screw through the door into the plate to hold it then another through the mirror into the plate loosely removed the first screw and put it back in through the mirror.
landarts
![]() Join Date: May 2005
Eliminated the plate and used rivet nuts. Easier to install, helps to prevent future rust and easy to remove mirrors if needed.
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
landarts
Here is a truck I installed rivet nuts on.
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
I used the plate as a template, drilled 1/4" holes in the door, glued the plate with 5-minute epoxy, then screwed the mirror on. The oversized holes in the door skin eliminated having to screw through the door skin and the plates. Apparently the factory backing plates were threaded to factory machine screws whereas the aftermarket Counterparts versions use self tapping sheet metal screws. The right side mirror locates farther back toward the rear of the truck so the wing window pillar does not block the view...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
