Old 08-02-2020, 06:52 PM   #1
4th Gen C-10
Junior Member
Wheel/Tire Help
Hey everyone.
I am planing on running these on my 69 C-10 long bed.
https://www.bozeforged.com/doons.html
Plan is 18x8 on the front and 18x10 on the back. Truck is dropped static 3.5/5 with a C-notch. Rear end is original 12 bolt. CPP disc brake conversion front and back.
Question #1: What backspacing should I go with on the front and back? I don't want to have to worry about any rubbing.
Question #2: What size tire should I go with? Looking for a bit of sidewall.
Jaybo
4th Gen. C-10 Build Thread
4th Gen C-10 is offline   Reply With Quote
Old 08-02-2020, 07:33 PM   #2
gmc684x4
Re: Wheel/Tire Help
67 72 c10 basic tire hight is 28.5 inchs tall
Myself i am looking
at keeping more a stock width tire as well maby a little wider
235 75 15
235 60 18 or 235 65 17 tire
I drive long distances and plan on keeping front and back the same size
1 spare tire to keep
Posi diff does not like two un equal tire sizes
gmc684x4 is offline   Reply With Quote
Old 08-02-2020, 10:20 PM   #3
gmc684x4
Re: Wheel/Tire Help
Here is american raciing wheel guide work sheet
https://www.americanracing.com/wheel-measure-guide/
Old 08-03-2020, 09:53 PM   #4
siggyfreud
siggyfreud's Avatar
Re: Wheel/Tire Help
Many people running an 8" wheel (9" wide in reality based on how wheels are measured) run anywhere from a 4.25-5" BS in the front, and 5.5 for a 10" on the rear. That said, your rear may be narrower than some of those running a 5.5BS for the rear, as many of the threads are 71-72 C10s which have a slightly wider rear end.
What I'd do is borrow or buy a wheel mock-up tool and check it out. I borrowed mine from Matt's Classic Bowties since I was ordering my wheels through them, but I imagine there are other vendors out there that loan them out too.
I then had a mobile tire company bring out 3 different sized tires so I could mock it all up. Once I knew what I needed, I ordered the wheels and tires and was pretty confident they'd all fit well.
The wheels you selected look nice. I'm having a hard time getting past their website which looks about 15 years out of date .
siggyfreud is offline   Reply With Quote
