08-03-2020, 05:15 PM | #1 |
Carpe manana
Hard vacuum line to the carb - questions.
I’m curious about the hard vacuum advance line. All motors? All models? Different styles for different years? What about AIR equipped motors? Affixed with spring clamps at the rubber hose?
Can anyone shed details? Neither of my SB motors have these so looking to add if original equipment. A BB motor I used to own did have this line. Borrowed example pics show the line joining the carb on the LH front port.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
08-03-2020, 07:02 PM | #2 |
Who Changed This?
Re: Hard vacuum line to the carb - questions.
Vacuum likes generally just have a bubble flare since the outside air tends to compress the hose a tiny bit, so no clamps. I've only ever seen clamps on the brake booster hose but I expect that that's because the engine moving could eventually work it loose. The vapor canister lines also had clamps, now that I think about it. At least the one to the carburetor vent.
~Steven '70 Chevy 3/4T Longhorn CST 402/400/3.56 Custom Camper Simi Valley, CA Last edited by Steeveedee; 08-03-2020 at 07:24 PM. Reason: spelling |
08-03-2020, 07:43 PM | #3 |
My 71 K1500 with v8 350 had the hard line from the Distributor to the CEC valve. I'm not sure what years used the CEC valve that turned the vacuum on or off based on several different engine/transmission conditions. When I acquired my truck the hard line was present, but the CEC valve was bypassed. I've never really figured out the correct routing as every way I've tried doesn't seem right. I would like to see any photos out there that show the factory routing.
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
08-03-2020, 07:51 PM | #4 |
In my photo in post #3, the hard vacuum line looks kind of correct. I big chunk of the line ran down the valve cover rail, which would make sense. What throws me is when I try to route it to the CEC valve and not directly to the carb.
08-03-2020, 08:01 PM | #5 |
20' Daredevil (Ret)
My truck is in paint prison so I can't take a look right now. Best as I can recall, the hard line looks like the second pic in post #1. Short rubber hose on each end, no clamps, and I'm pretty sure it's original to my California K20.
08-03-2020, 08:26 PM | #6 |
Carpe manana
Thanks for posting. FWIW Inline Tube lists a repro in their catalog for 71-72 (steel and stainless). I’ve ordered one to try and I’ll post a review. With IT though you never know 1) if it will fit or 2) if they send what you ordered
https://www.inlinetube.com/products/ctv7103
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 08-03-2020 at 08:27 PM. Reason: Added |
08-03-2020, 08:32 PM | #7 |
Carpe manana
The 1/2 tons in 71-72 had the solenoid for the TCS mounted along the RH head. I’ll dig for a schematic as I’m curious how it ties into this hard line if at all.
Edit: Maybe the line serves to supply the manifold vacuum port on the vacuum advance solenoid for the TCS set up? For 3/4t pickups that weren’t equipped with TCS maybe the rubber hose was just a tad longer going right to the distributor from the rear of the hard line?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 08-03-2020 at 09:03 PM. Reason: Added. |
08-03-2020, 09:54 PM | #8 |
Carpe manana
Here’s an example also form the service manual albeit a Mark IV engine
08-03-2020, 11:47 PM | #9 |
Here are pictures of what's original to my '69 C20 with a 350 and no emissions other than a PCV. They show rubber at the ends and steel in between and no clamps. I believe the original rubber line to the vacuum advance was a bit shorter.I transferred the clip in the last picture from the original engine to my crate engine. It was attached to the hard line and the intake.
Jim |
08-11-2020, 10:23 PM | #10 |
Carpe manana
Jim thanks for posting. Now I need to locate two of those tiny clips.
The Inline Tube piece looks like a decent match and it seemed to fit well. Arrived inside a bubble pack. I’d recommend it. They offer a stainless version also.
08-11-2020, 11:15 PM | #11 | |
https://www.corvettecentral.com/c3-6...cuum%2badvance
Jim |
08-11-2020, 11:23 PM | #12 |
I also found these valve cover clips for the temp sender wire. They look very familiar, but it looks like my '58 Vette has them. However, they'd work well with aluminum valve covers and possibly steel on these trucks.
https://www.corvettecentral.com/c3-6...n-valve-302055 Sorry for the subject change... EDIT: After checking further, I think my original valve covers had/have clips welded on to the left valve cover. I'll have to check.
Jim Last edited by FirstOwner69; 08-12-2020 at 12:17 AM. |
08-12-2020, 01:04 AM | #13 |
A 72 K20 that I restored only had one clip holding the steel line and no clamps. My 70 K20 that I'm working on now has the same single clip and a similar steel line.
Before and after restoration pics of the 72 K20 - Miles |
08-12-2020, 07:40 AM | #14 |
Carpe manana
Very helpful thanks guys. I ordered a pair of the clips.
08-12-2020, 10:39 AM | #15 |
Only one on mine also.
Jim |
08-12-2020, 11:26 AM | #16 |
Carpe manana
Thanks - I've ordered one for each motor that needs it
