Old 08-03-2020, 05:52 PM   #1
1-PU70
1-PU70's Avatar
Brake line routing ?
Anyone have any idea why the rear brake lines on my 70 c10 has the rear brake lines routed on the right side. They start on the left (master cylinder) then cross over to the right side (under the motor) then go down the right side to the rear and back to the center. It would have used less material, less bends and I just think easier. Did GM have a reason they did it the long way. Just curious.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 08-03-2020, 08:47 PM   #2
firedemon
Re: Brake line routing ?
my 67 is the same . when i replaced mine looking in the books i think the only difference was long or short bed so i think they are all that way
firedemon is offline   Reply With Quote
Old 08-03-2020, 09:07 PM   #3
gmc684x4
Yes two wheel and 4 wheel drives are done that way
I figure it was there way of helping balance front and rear brakes in conjunction with the proportioning valve on with drum brakes and carried that setup through into disc brake setups
gmc684x4 is offline   Reply With Quote
Old 08-03-2020, 09:54 PM   #4
BigBird05
With all of the lines, both brake and fuel going down the same side of the truck, it was probably easyer AKA cheaper, to assemble the truck. Two men, one in the front, one in the rear put the line bundle on the frame and tighten down the screws.
BigBird05 is offline   Reply With Quote
Old 08-04-2020, 10:28 AM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
ALL of these trucks came that way from the factory.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-04-2020, 04:59 PM   #6
LS short box
When I did the frame off on my 68 C10 LS swap I ran both fuel and brake lines down the drivers side. I built my brake lines. Used Ni-Copp lines.
LS short box is offline   Reply With Quote
Old 08-04-2020, 07:00 PM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Brake line routing ?
Brakes & fuel both run down the passenger side on these trucks.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-04-2020, 08:09 PM   #8
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
The reason is fire safety, there is a code that requires electrical and flammable be routed x number of inches apart. The electrical that must be located in proximity to flammables must meet a code and\or use a resistance sending unit designed for use in flammables. All that safety and put the tank in the cab right? The big three only did what they had to do via the codes written by suits that never had a busted knuckle...Most were good, some didn't make any sense...Here's one that stifled engineers I confronted in the auto plants for 40+ years..."Whats the difference between pipe and tube?"
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 08-06-2020, 03:44 PM   #9
GASoline71
GASoline71's Avatar
Exhaust goes through a pipe.
Fluids go through a tube...
Gary
