Old 08-03-2020, 07:34 PM   #1
Root2812
Root2812's Avatar
Transmission placement
Hi guys. I’ve done the research and know about equal and opposing angles. I got the up and down angles set. It’s side to side I’m worrying about. I have my crank bolt dead center in the frame but my centerline of the tail housing on my transmission is just under 1/4 to the passenger side. I’ve already used up what wiggle room I had in the mounting holes. Before I go and oblong a hole on my crossmember to shift the mount over I figured I’d ask if it were really necessary. It shouldn’t matter but I am running a ford 8.8 with an offset diff.
I figure it’s safer to ask then remove metal than remove metal then ask.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 08-03-2020, 07:40 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Transmission placement
What engine?
Trans?
2WD or 4WD?
1/4" at the trans mount is not much....but it should be centered....
Loosen the engine mount bolts a little and slide the trans across that 1/4".
Then tighten everything down again...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 08-03-2020, 07:48 PM   #3
Root2812
Root2812's Avatar
Originally Posted by AussieinNC View Post
What engine?
Trans?
2WD or 4WD?
5.3L w/ 2wd 4L60e. Transmission mount is the one center bolt style from the donor Silverado. I already loosened up the motor mounts and pushed it over. The last 1/4 is going to have to be gotten from modifying something.
This is my first build and everything is custom so I think I did alright getting it there so far. Fine tuning now before the body goes back on. If it has to go over I’ll oblong the hole in the cross member I made.
My 1950 Chevy build
Old 08-03-2020, 07:57 PM   #4
mongocanfly
Post Whore
mongocanfly's Avatar
The engine trans can be offset without issue...it just needs to be perpendicular to the axle..
1/4" out isnt much, like aussie stated, but I try to get mine as perfect as possible...
Like he said, see if you've got wiggle room in the motor mounts...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-03-2020, 08:02 PM   #5
Root2812
Root2812's Avatar
Thanks guys. I got tired and called it an evening on it for today. I’ll hit it again tomorrow and see if I can wiggle it a little more.
My 1950 Chevy build
Old 08-03-2020, 09:14 PM   #6
LS short box
1/4" offset is well within the 1950's specs. But if you can just slot the mount a bit to get it perfect I would go for it.
LS short box is offline   Reply With Quote
Old 08-11-2020, 05:27 PM   #7
tinydb84
tinydb84's Avatar
For 1/4'' I wouldn't worry. You can oblong the hole now or later if you get vibrations. Double check to make sure everything in the chassis is straight though.
David
Instagram: myfabguy
Old 08-15-2020, 07:54 PM   #8
truckdude239
truckdude239's Avatar
where we suppose to check thT stuff? Lol I literally just threw my adapter plates in drop motor and trans in slid my trans meter back 5 or 6 inches mount fell right in whole and re drilled frame forcross menber so id amagicne the 1/4 wont hurt
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-16-2020, 12:52 PM   #9
Tork?
An adj panhard bar would get you 1/4" on the axle end
Tork? is offline   Reply With Quote
