08-04-2020, 08:12 PM | #1 |
Repairing a rusty cowl on my 72.
I've got a question for all of you body men out there. I have a rusty inner cowl. I know strange, right. You can see day light thru it above the brake pedal. I was lucky enough to find a rust free inner cowl at the junk yard, so I bought the whole upper half of the fire wall and dash. My question is should I only replace the bad rusted out piece and have a seam that runs about 30 inches long and leave the windshield frame alone, or replace the whole inner cowl for about 30 inches, plug weld the fire wall and windshield frame at the spot welds and only have about a 8 to 10 inch seam over by the wiper arm mount.
08-07-2020, 09:10 AM | #2 |
Re: Repairing a rusty cowl on my 72.
Take this with a grain of salt because I have never done this, but I think I would break the seam at the window. It will make a cleaner install overall and you get away from an extra 22" of butt weld and grinding. The less I have to weld the better!
Not saying it will be easier, but it is what I would do. Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
08-07-2020, 03:08 PM | #3 |
Could you post some pics of what you're dealing with? I'd probably go to the windshield but I'd like to see the extent of the damage first.
Nick 1961 Apache short stepside 4X4 SBW 348/4 speed 1960 Apache C-20 long fleet custom cab BBW 283/4 Speed 1967 rust bucket Olds Cutlass with a 455 1972 GMC K-15 350/4 speed long fleet |
08-07-2020, 08:08 PM | #4 |
ApacheNick, I can't post photos because I am comp. challenged.
08-08-2020, 11:49 AM | #5 |
You use post reply
Look below click on manage attachments Opens in a new window may need permission to open Top buttons select pictures in same box lower right click upload pictures After pictures upload you can close window Back to reply thread click submit |
