Old 08-06-2020, 12:19 PM   #1
72blue
72blue's Avatar
What air cleaner in a 4wd?
Long time listener first time called here. Well, not first time; just long time since my last post. I have a 72 that has a small block 383 and I am running an Edelbrock 1826 650 cfm carb and now am switching to a Holley. My air cleaner is a 14 by 4” round k&n with 1 1/4” drop bass and just barely tucks under the cowl. This is a 4x4 K10 short fleet. I am assuming with the Holley the air cleaner will be in the same spot and drop base will not fit over the Holley, thus raising the air cleaner into the cowl. What are my options? Show me what you got please!
James
72blue is offline   Reply With Quote
Old 08-06-2020, 12:29 PM   #2
cj847
cj847's Avatar
Re: What air cleaner in a 4wd?
Here is how i found mine. I got the Wix PN then cross reference if you cant find Wix brand.
https://www.wixfilters.com/Lookup/FilterBySize.aspx
cj847 is offline   Reply With Quote
Old 08-06-2020, 12:37 PM   #3
Ziegelsteinfaust
14X2 K&N style filter is more then enough for 500+ hp. So you could use a shorter filter, and not loose anything there.
Since you live near Pismo I would suggest a K&N pre filter so sand does not get packed into the filter. It robs a few hp, but well worth it.
https://filterwears.com/collections/k-n
I used one to dress up my F150 I dolled up to bomb the dunes, and found out it honestly worked quite well. My air filter was fine, but my friends were packed with sand. They had to sacrifice t-shirts to finish up the day off road.
Ziegelsteinfaust is offline   Reply With Quote
Old 08-06-2020, 03:48 PM   #4
72blue
72blue's Avatar
Good idea. I am looking at those filter wraps now. Thanks guys.
James
Old 08-08-2020, 08:24 AM   #5
Mike C
Mike C's Avatar
The reproduction GM drop base air cleaner (65-71 Corvette, 67-69 Z/28) sells for about $50 base only and drops significantly more than any of the aftermarket dropbases and is profiled to clear a Holley carb
On my Jimmy I have a no-drop base with a 4" K&N and it clears by just a little. The stock setup with the spacer that connects to the valve cover vent was so tall there is usually plenty of room in these trucks.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-11-2020, 12:28 PM   #6
72blue
72blue's Avatar
Thanks for all the input. I will post up what I come up with. Good to know it clears with a no drop base. I have the same element as you, so we will give that a try.
James
