Old 08-07-2020, 03:22 AM   #1
70cst
70cst's Avatar
Is your 5.3 buring oil ... possible fix.
GM has a Valve Cover that has been re-designed that might solve this. Looks promising.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-07-2020, 04:37 AM   #2
jjzepplin
jjzepplin's Avatar
Re: Is your 5.3 buring oil ... possiblefix.
Where is this cover? I was looking at the LS6 valley pan that has a built in pvc type thing that eliminates your in line pcv. Looking inside my intake looks like I have missed quite a few oil changes inside my fuel tank.?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-07-2020, 09:43 AM   #3
70cst
70cst's Avatar
Driver side manifold cover ...
Old 08-07-2020, 10:09 AM   #4
jjzepplin
jjzepplin's Avatar
Re: Is your 5.3 buring oil ... possible fix.
Oh. I thought you were serious. My bad.
Old 08-07-2020, 10:42 AM   #5
71cadc10
71cadc10's Avatar
https://www.amazon.com/gp/product/B0...S9DDBKSM&psc=1
the baffle inside is the new piece that was re-designed. I'm going to try this on my 2009 Yukon that fills the intake with oil and smokes
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 08-07-2020, 10:46 AM   #6
jjzepplin
jjzepplin's Avatar
Oh. You were serious. I am interested. Let us know the results.
Old 08-07-2020, 07:36 PM   #7
70cst
70cst's Avatar
I should have said Valve Cover ...
Old 08-07-2020, 08:21 PM   #8
hatzie
Moderator
hatzie's Avatar
Updated valve covers are mentioned in GM Technical Service Bulletin 10-06-01-008M
The link is a PDF of said TSB
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 08-07-2020, 09:25 PM   #9
70cst
70cst's Avatar
Old 08-09-2020, 09:57 AM   #10
jjzepplin
jjzepplin's Avatar
Oh thank you! I suppose this fix should work on most LS engines. I now have 3. I just bought a 2014 GMC 5.3. I also have a 99 5.7l and a 2006 6.0 LQ9. I can use this info on all 3 most likely.
Old 08-13-2020, 08:18 AM   #11
70cst
70cst's Avatar
I'm installing the new Valve cover next Monday so hopefully my excessive oil use will decrease.
Old 08-13-2020, 11:35 AM   #12
Desert1957
Desert1957's Avatar
You sure about this bulletin? Sheet says years affected start at 2007?
Desert
Desert1957 is offline   Reply With Quote
Old 08-13-2020, 11:57 AM   #13
70cst
70cst's Avatar
I am fairly confident ... I spoke to my GMC dealership and they said the vlve cover was redesigned ... which syncs with the oil consumption issue.
Old 08-13-2020, 05:35 PM   #14
hatzie
Moderator
hatzie's Avatar
The valve cover was re-designed for AFM (displacement on demand) engines but that doesn't mean the non AFM engines will not benefit from the re-design.
Old 08-14-2020, 02:31 PM   #15
70cst
70cst's Avatar
I will find out after next week if this cuts my oil consumption ...
Old 08-14-2020, 03:35 PM   #16
This is an interesting conversation about oil consumption and synthetic oil use.
https://www.youtube.com/watch?v=tDpTPxinNyo
Old 08-14-2020, 06:29 PM   #17
70cst
70cst's Avatar
Old 08-19-2020, 07:55 PM   #18
70cst
70cst's Avatar
My 04 Sierra now has the GM redesigned Valve Cover ... so lest see if it works.
Old 08-20-2020, 10:56 AM   #19
jjzepplin
jjzepplin's Avatar
I can't wait for some results.
Old 08-20-2020, 01:35 PM   #20
hatzie
Moderator
hatzie's Avatar
If it was motor oil getting sucked through the PCV breather system and not from excessive cylinder wear it should make it better.
I'm interested to see what happens.
Old 08-20-2020, 10:30 PM   #21
70cst
70cst's Avatar
Its now a waiting game ...
Old 08-20-2020, 10:32 PM   #22
70cst
70cst's Avatar
I know it had something to do with the PCV Valve and the new design has a different designed baffles.
Old 08-25-2020, 08:19 PM   #23
truckdude239
truckdude239's Avatar
I had new cover installed in January along with all my leaks fixed I went from 2qts of oil every 1k miles to about 1 qt every 1500 I use to have smoke if I left it idleing for awhile and cut it off and restarted now I have no smoke at all so I believe it works this is on my 2002 suburban they do sell a pcv vavle with just a small hole in it that was suppose to help oil usage it didn't work for me but the vavle cover did
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-25-2020, 10:33 PM   #24
70cst
70cst's Avatar
Good info
