Lift kit advice
I'm finally ready to order a 4" suspension lift for my 1985 K30 454 pickup and need to know if the wheels and tires I want are going to clear everything. The wheels are 17x10 US Indy with 4.5 BS, the tires are going to BFG's 33 x12.50 x 17. It'll be a street driven truck with some light off roading. I called ORD design and they thought 33's would clear, but I want o be sure. I'm also looking at a Skyjacker C14OCK kit. My truck is a big block with AC, so I'm guessing I'll have to add the F1c140 HD spring?
Re: Lift kit advice
i prefer tuff country and with bbc 454 go HD springs .
and yes 33" will clear with 4" lift and the k30 is just over 1" taller than 1/2 and 3/4 ton trucks . i run 255/85/16 ( skinny 33" ) on 3" lift on stock rims . i have a sbc 350 but run a fisher 8ft snow plow in the winter thats over 800lbs total on the front .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
Re: Lift kit advice
That's a good looking truck with a seldom seen color combo. ( around here anyways) Thanks for the advice, I THINK ORD sells Tuff Country lifts, I'll call them again.
Re: Lift kit advice
IIRC, that truck started life as a 2wd lol. But ORD doesn't sell BS, anything they sell is top notch stuff. As already mentioned, 1 tons sit higher than the 1/2 and 3/4 tons, and can clear 33s on a 1/2 ton, so really would only need a 2 1/2" to clear....
Re: Lift kit advice
I read where the K30 frame is different in the rear, , but where is the extra 1" lift coming from in the front? I work out of town M -F, so I usually order stuff on Saturdays thru Summit. I did just set up an account with ORD and will try to call them next week.
Re: Lift kit advice
dana 60 is a BIG front axle . years ago i swapped one under a k10 and took out the 3/4 ton 10bolt and i got almost a 1inch more height .
and b454rat yes this was a 2wd body swapped on a k30 frame . . . but not the one you know of . she had to be retired after 13 years and the last 3 were limped alone barly .
Re: Lift kit advice
This is the 1st k30 that I've owned, until now I've always had k 20's, thanks for answering that, now I know. I've also converted 2wd cabs over to 4x4 frames, EZ to do and as good as factory. It was a lot easier to find 2wd cabs as opposed to finding a 4wd.
Re: Lift kit advice
all my current trucks have 2wd 1/2 ton bodys on them . 3 k30 trucks . and a c-10 short bed truck but thats a given . . .
Re: Lift kit advice
and since its your first k30 and lifting it a bit watch the 1 rear shock to axle tube for fitment . on the k30 the rear shocks mount different and the rear getting lifted and rotated just a few degrees can make the 1 shock body contact the axle tube . easy to fix tho . cut the mount off and rotate it a few degree back and re-weld it back on .
Re: Lift kit advice
Good to know, another difference between the k20 and K30 trucks. Since the K30's are 1" taller, my plan NOW is to go with a 3" lift, Tuff Country HD springs, and 3" blocks in the rear. I see ORD offers a shackle flip, but I'm old school and that's all new to me, and blocks will be fine. I'm trying to keep the lift as low as possible, run real 33 x 12.50's and still have the right amount of space between the top of the tire and fenders for the right look. Guessing I'll need a drop pitman and steering block?
Re: Lift kit advice
Here is my K20 with 3" Tuff Country ez rides and 16x10 wheels on 33x12.50's no rubbing
Re: Lift kit advice
#13 |
Re: Lift kit advice
Very nice! Looks like a 3" will work fine. If I ever decide to paint my pieced together rig, it'll be some shade of blue or green. I'm also looking at BFG or Cepeks, haven't decided yet.
#14 |
Re: Lift kit advice
do a drop pitman arm first . thats what i have on mine . the steering block spacer is not the best .
and dont forget cooper tires . there a real good brand and i never had any problems with them when i did tires for 15+ years . bfg is still good but there getting real pricey and some quality problems i just read up on . the bfg radial t/a tires for older hotrod stuff there is a massive problem with the white letters not being white and staining fast and wont come clean . i just got 4 cooper cobra tires for my 2wd and it was just over 1/2 price of the bfg tires and the letters are solid white and look great . and my k30 has the bfg mud tires and they wear out FAST . i have under 10k miles and there half tread now . 1 more winter and there done . next set will be cooper tires .
#15 | |
All about them K’s
![]() Join Date: Jun 2014
Re: Lift kit advice
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
#16 |
Re: Lift kit advice
I have Coopers on 2 of my daily driver cars, they seem to last and were cheaper than BFG's, also looking at General tires. The longest lasting passenger car tire I've ever owned was Uniroyal tiger paws, 60,000 miles and 3 were still good enough to sell to the dealer. If I go with BFG, they'd be the all terrain, but have to get the rims here first. I'm trying to keep the complete lift, wheels and tires under $3,500. Don't know if that'll happen though.
#17 |
Re: Lift kit advice
I will say Sykjacker
Lift kits that are half its price will be much rougher ride Do not be cheap and use the kits with rear blocks front end usually always sit higher then the back doing it this way I run Duratracs mining they last over a year in that extreme rough environment I used to like bfgs i found on anything other then a halfton they had a very short liftime on a 3/4 and 1 ton and burned up very quickly towing |
#18 |
Re: Lift kit advice
I have Falken Wild Peak AT2 as I think they are called, on my tundra. 35x12.5x20, had em 2 years now and looks like I put em on yesterday. They are pretty good in the snow, not so great in the mud, but they aren't a mud tire either. I had a tough time in my yard last spring lol. Don't think they are white letter, but anymore I prefer black wall. General Grabber is another good one I've had. Great in snow, just don't do mud anymore so can't say how they do there.
#19 |
Re: Lift kit advice
It's a bummer, going from 3" wide springs to 2".5, but that's what I can find in a 3" lift.
#20 |
Re: Lift kit advice
I took SweetK30's advice and went with 285 x 75 x16 and I'm really pleased with the fit. The wheels are a made in USA 16 x 8 chrome spoke form US Wheel,(waiting on lug nuts and center caps) the tires are BFG, Tuff country 2" HD spring, ORD HD shackles and dana 60 stud kit. The total front lift ended up being 2 3/4". I still have to :raise the stock rear springs about a 1/2" , have steering box rebuilt, longer front shocks and new sway bar bushings.
#21 |
All about them K’s
Re: Lift kit advice
Looks great, I really like it. It’s nice when they sit up a bit but are still perfectly usable as a truck. I’ve had a few that were up high enough that they look great but aren’t practical at all.
#22 |
Re: Lift kit advice
Nice
| Bookmarks |
