Soft plug, core plug, ?
I originally posted this in the S10 forum, but no response, so I thought I would try it here, which is where I normally post (as I have a 67 C10). I fugure core plugs are about the same on any cast iron block:
One of the soft plugs (or freeze plugs or?) is leaking on my grand daughter's 1992 S10, V6. I think the manufacturer says that no sealant is needed, but that makes me a little nervous. Does anyone have advice on how to do this? Sealant or no? What kind of sealant? Brass or steel? Thanks in advance for any advice. |
Re: Soft plug, core plug, ?
Brass has always been my preference and I always use some high quality high temp sealer (RTV silicone). I don't think there is anything wrong with steel plugs...it's really no big deal either way. Just put a very thin smear of sealer on the plug perimeter and the same in the hole...very thin is all you need especially in the hole. In a new hole with anew plug...no sealer needed, but sometimes the hole gets scarred by the removal of a steel plug and the sealer is good insurance. Most of the sealer will squeegee off when the plug is installed. That's why you only put a very small smear in the hole otherwise it will squeegee off into the block. That won't be the end of the world, but the less silicone buggers in the coolant, the better.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
Post Whore
![]() Join Date: Feb 2016
No sealant. Brass is my preferred choice. It won't rust through and start leaking. Make sure the hole in the block is clean. You will need a driver for the new plug that is the correct size. Then be sure you drive the plug in square to the block in both planes. They are a tight crush fit. Some S10 4.3 plugs can be a real pain to get to. This video might help.
Good luck. https://www.youtube.com/watch?v=2zdnd5ikynU
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: May 2010
I know I'll probably get "flamed" for this since the preferred cure is to replace the plug, however...
If the leak is relatively minor try some of this stuff first. I've used it several times over the years on different leaks (including a freeze plug), and it's worked well. It is an organic compound that does not gum up the cooling system like some other products do. https://www.amazon.com/Genuine-GM-12...s%2C695&sr=8-2
Jim Last edited by FirstOwner69; 08-09-2020 at 04:51 PM. |
![]() Join Date: Jan 2001
I use Permatex aviation form a gasket as a light coating on the block opening. I prefer brass plugs, but I've used steel with no problems as well.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Thanks to all for the advice. I'll let you know how it goes.
#7 | |
If the leak is too big, of course replace the plug. It won't be easy with the engine in the vehicle though. |
#8 | |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#9 | |
Who Changed This?
![]() Join Date: Jan 2013
![]() Join Date: Aug 2019
I worked for the factory and we always use sealer on the new engines.
#11 | |
Who Changed This?
#12 | ||
"I ain't nobody, dork."
I use "Indian Head" on brass plugs too.
Most leaks I've seen are from steel plugs rusting, or from new plugs (steel or brass) hammered in too far. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
