Old 12-14-2003, 03:30 AM   #1
skokie
skokie's Avatar
Changing Rear End Fluid
I was planning to open up the rear end and see what gear ratio I have and while I was in there change the fluid. I realize that removig the fluid is the easy part but how do you put more in? How much does a 1/2 ton 12 bolt take?
skokie is offline   Reply With Quote
Old 12-14-2003, 03:47 AM   #2
lost wages
lost wages's Avatar
should be a plug about halfway up the diff cover, it will take 3-4 bottles of gear oil, not real sure fill it till it runs out the fill plug, if you have a limited slip make sure you have some fritction modifier, you can get it at parts store or tranny shop/
lost wages is offline   Reply With Quote
Old 12-14-2003, 03:50 AM   #3
skokie
skokie's Avatar
Facing the rear of the truck is the plug on the left or the right? Not sure if I have limited slip or posi. Thats another reason I am opening this up. Plus I am pretty sure the previous owner didnt change it.
Old 12-14-2003, 04:24 AM   #4
1969 GMC
1969 GMC's Avatar
I'm not sure what side the plug should be on a 12 bolt, but there should be only one drain plug on a diff cover, it's a big square headed plug that sticks out.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 12-14-2003, 04:31 AM   #5
lukecp
Formerly yellow72custom
lukecp's Avatar
There isn't a drain plug on a stock 12 bolt cover (unless someone has modified it).
The fluid goes in on the passenger side of the differential, on the same side as where the driveshaft goes in. Look around and you will find it...it comes out with a 3/8" ratchet.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-14-2003, 04:39 AM   #6
skokie
skokie's Avatar
Ok sounds good. Thanks again
Old 12-14-2003, 04:45 AM   #7
1969 GMC
1969 GMC's Avatar
d'oh my bad...i'm used to my dana 60. sorry
1969 GMC K2500
1996 Honda Accord
Old 12-14-2003, 04:45 AM   #8
lost wages
lost wages's Avatar
yup yellow is right, i changed my oil in my dodge today and thats why i thought of it being on the cover, my 68 has a ford 9 inch so i havent seen a 12 bolt in a while! heres a link i found for you. http://www.sporttruck.com/techarticl...03/index1.html
Old 12-14-2003, 11:58 AM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If you have the cash and do any seriouse RPMs (like high speed cruising) or tow any heavy loads in a regular basis...sythetic is not a bad idea.
Many will scoff at the idea, but our lab shows that it does indeed help more than most ppl would ever think.
Acording to our lab, if your oil is original in there, and it has the typical 3.73 or numeracly higher gears, and asuming you have over 100K on the clock..your oils is only working at about 25%- 45%.
This is an independent lab that we deal with all the time for the past 12+ years.
Old 12-14-2003, 12:24 PM   #10
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
anyone have a certain brand that they swear by when changing the gear oil im thinking mine has over 200K on it and it may not be a bd idea to change it
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-14-2003, 12:46 PM   #11
MJN
MJN's Avatar
I would use Mobil 1 if you go with synthetic, otherwise Mobil or Valvoline 80w-90 will work fine. If it is a factory posi and has the little clutches in the diff, then you will need GM's friction modifier. It comes in a 4oz bottle andyou just dump it in with the oil. I found this out the hard way, I tried using a friction modifier from Napa but kept getting a clunk when the diff would engage, after putting in the GM stuff the clunk went away and never had another problem. Hope this helps.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 12-14-2003, 11:05 PM   #12
70c10
67-72 Addict!
70c10's Avatar
My Eaton Posi came with instructions NOT to use synthetic. I wanted to use it anyway but figured I would just go with the regular stuff.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-15-2003, 01:23 AM   #13
Longhorn Man
Good point. I guess I would say to look into it if you have a posi or locker.
Old 12-15-2003, 04:57 PM   #14
MJN
MJN's Avatar
I replaced the rear end oil in our '94 Jimmy and it has a locking differential in it and the Moblil 1 synthetic hasn't hurt it one bit, made sure to get the GM additive too.
Old 12-15-2003, 08:14 PM   #15
skokie
skokie's Avatar
Ok its drained man that stuff was nasty. Barely any in it at all and there was no gasket either. So now its all filled up with a new gasket on it and here are the numbers that I pulled off of the ring gear.
381777811:41 GM168219-1
Old 12-15-2003, 09:00 PM   #16
lukecp
lukecp's Avatar
If those numbers mean 11:41, you have 3.73 gears.
Old 01-17-2004, 03:55 PM   #17
Quagmire
A splendid one to behold
Quagmire's Avatar
somebody mentioned 4 or 5 bottles, does that mean quarts?
67 swb
02 wrx
Quagmire is offline   Reply With Quote
Old 01-17-2004, 04:24 PM   #18
cableguy0
just fill it untill it starts leaking out of the hole your putting it into. then put the plug back in
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 01-17-2004, 04:31 PM   #19
lukecp
lukecp's Avatar
It is about a quart and a half...buy two bottels and you will be good.
Old 01-17-2004, 08:31 PM   #20
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
somebody correct me if i'm wrong but i think the 3:73's were in pretty much all of these trucks. Mostly one wheel wonders if you had 2 wheel drive
WRMZ71 is offline   Reply With Quote
Old 01-17-2004, 08:55 PM   #21
lukecp
lukecp's Avatar
I would guess 3.07 to be the most common (for C10's anyway). , but i don't have any numbers. Just about every 350/auto truck has 3.07's...and that is what most of these trucks are. 3.73 is an easy second...with all inline trucks coming standard with 3.73's and most 307/283 trucks too.
I've seen like one in person with factory posi, lol.
Old 01-19-2004, 05:32 PM   #22
Quagmire
Quagmire's Avatar
thx guys just trying to get an idea, i order all my oil, etc. just didn't want to order to little or too much. that stuff is pricey
67 swb
02 wrx
Old 01-19-2004, 05:51 PM   #23
skokie
skokie's Avatar
Yep and it smells great to
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
Old 01-19-2004, 06:42 PM   #24
Quagmire
Quagmire's Avatar
yeah, my garage has been stinking for a week now
67 swb
02 wrx
Old 01-19-2004, 09:43 PM   #25
67dragtruck
67dragtruck's Avatar
amount of fluid
If my memory is correct it takes between 3-4 bottles (quarts)
Tom
67dragtruck is offline   Reply With Quote
