Old 08-09-2020, 03:14 PM   #1
whatleyr
Headlights don't work! Help!
IT NEVER FAILS! Take you classic truck to get inspected and the lights don't work.
All of my lights inside and out of my 65 c10 work just fine except the headlights. The lights will not come on when you pull the switch. I thought the bulbs were bad but when I push the dimmer in the floorboard, they come on. SO low beams are not working. I'm not an electrician so please help me trouble shoot this so I can get this thing inspected. Thanks in advance.
whatleyr is offline   Reply With Quote
Old 08-09-2020, 05:00 PM   #2
bigmoe
bigmoe's Avatar
Re: Headlights don't work! Help!
Must be the dimmer switch.
bigmoe is offline   Reply With Quote
Old 08-09-2020, 10:14 PM   #3
whatleyr
How can I test it before confirming it is indeed the dimmer switch? Thanks
Old 08-09-2020, 10:45 PM   #4
bigmoe
bigmoe's Avatar
Pull the dimmer switch and test it. Although they are pretty cheap to buy if you just replace it and try.
Old 08-10-2020, 04:12 PM   #5
plmadding
Just noticed my 66 C20 is doing the exact same thing. Dimmer switch seems like the most likely culprit.
plmadding is offline   Reply With Quote
Old 08-13-2020, 05:30 PM   #6
SCOTI
SCOTI's Avatar
To add to the suggestion.... Testing can simply be pulling/disconnecting the dimmer switch out of line & jumper the connections to see if the headlights come on.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-14-2020, 12:49 AM   #7
slepysal
slepysal's Avatar
check the fire wall plug
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
