Old 08-10-2020, 06:57 PM   #1
michael bustamante
michael bustamante's Avatar
Routing the harness thru the cab
So I bit the bullet and bought a harness. But I have a couple of questions. First off what are you guys doing to route the harness into the cab? Are you cutting a hole in the floor are you running it through the firewall? I'm at a loss there. I'll attach a picture to show The grommet that came with the harness. Second I cannot find the purple starter wire on this harness anywhere. What's going on with that? PSI harness
1967custom
michael bustamante is offline   Reply With Quote
Old 08-10-2020, 07:06 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Routing the harness thru the cab
You will reuse your old starter wires...they are Independent of the LS harness...
On the grommet I've been drilling the grommet hole above the driver side valve cover...then I run all my under hood wires thru the grommet..you can run it anywhere you feel comfortable with and have clearance on both sides of the firewall...
It's a gripe of mine about the psi harness...theres to much wire to easily fit under the dash, and not enough wire to reach under the seat...which is where I want mine...would be nice if it was a ft shorter or a ft longer
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-10-2020, 08:04 PM   #3
michael bustamante
Yeah I was looking at that too. It's not enough to go under the seat at all so I guess I'm going to have to mount the computer under the dash somewhere. But on my OEM harness it had a purple wire on it that I just tapped into. so now I just want my old wire directly to the starter like usual?
1967custom
Old 08-10-2020, 09:00 PM   #4
mongocanfly
Post Whore
Correct ..all you need is the wire from the switch to the solenoid...and it should run thru whatever safety switch you have
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-10-2020, 11:54 PM   #5
michael bustamante
Ok cool man thank you.
1967custom
Old 08-11-2020, 10:41 AM   #6
nsb29
nsb29's Avatar
I went with BP automotive which was long enough to go under the seat Was very happy with their harness it came with high pressure transducer for the AC as well as a signal wire for the speedometer some of the Others I inquired about did not
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 08-11-2020, 11:18 AM   #7
mongocanfly
Post Whore
I'm thinking ill use a BP on my AD when I get to it...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-11-2020, 01:13 PM   #8
Pontitruck
Pontitruck's Avatar
This is what I used as well and i am in the process of tucking it and the TAC harness/module away as well.
Pontitruck is offline   Reply With Quote
Old 08-11-2020, 02:17 PM   #9
Ramiro0727
Here is where I mounted ECM and where the harness goes into the engine compartment. The harness was PSI also.
Thanks,
Ramiro
Ramiro0727 is offline   Reply With Quote
Old 08-11-2020, 04:05 PM   #10
nsb29
nsb29's Avatar
Thanks,
Ramiro
No A/C ?
Old 08-11-2020, 04:30 PM   #11
LS short box
I like to hide as much wiring as I can.
I mounted the ecm behind the glove box. No ac. Had to notch the glove box a bit to make room for the ecm. Fuel pump and fan relays next to the ecm. Screwed the OBD port and fuse block to the heater box. Ran the engine harness low enough so you can't see it when you are in the truck. You can just barely see the grommet/harness near the left cylinder head with the hood up.
LS short box is offline   Reply With Quote
Old 08-11-2020, 07:30 PM   #12
Ramiro0727
No A/C ?
nsb29,
Its a ac cab. AC will come later. Trying to get the running on the road first.
Ramiro
Old 08-11-2020, 07:35 PM   #13
Ramiro0727
Here is a picture where the harness comes out to the engine compartment.
Ramiro
Old 08-11-2020, 09:25 PM   #14
LS short box
If you have the harness length available I would pull it down so the other wire bundles aren't seen. Here's a pic of mine. I use Howell harnesses and there is just enough length to hide the wire bundles.
Good luck with your swap.
Old 08-12-2020, 09:54 AM   #15
nsb29
nsb29's Avatar
nsb29,
Ramiro
The reason I ask was it appears your ECM and relays would be in the way of the AC
Old 08-12-2020, 02:06 PM   #16
michael bustamante
Thanks,
Ramiro
I was thinking about routing there too..
1967custom
Old 08-12-2020, 02:09 PM   #17
michael bustamante
Damn that's clean... All I see is that pink wire on the firewall... Them are good engine covers!
1967custom
Old 08-12-2020, 02:16 PM   #18
Ramiro0727
nsb29 when we are ready to install the AC. If there are in the way i will move them to a different spot.
Thanks,
Ramiro
Old 08-12-2020, 02:19 PM   #19
Ramiro0727
look great LS short box.
Ramiro
Old 08-12-2020, 09:25 PM   #20
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I brought mine into the cab through the floor and mounted the PCM and fuse/relay box under the passenger seat. You can see it in my 70 K10 build thread.
I drilled a hole for either 1-1/2" or 1-3/4" grommet (can't remember now)
PCM and fuse/relay box goes under passenger seat. I was going to keep the OBD2 port there too, but I decided to move it under the dash.
I used Blazer tilt brackets so I would have access to the PCM if needed.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
