Old 08-10-2020, 07:49 PM   #1
johnson1967
Will the wheels I found fit my 67 stepside
I'm in the process of getting everything ready to complete my 67 stepside I had a set of new 15x10s and 15x8s in the garage I was just curious if these would fit my truck that will be lowered 4 in in the rear and 2.5 upfront.
johnson1967 is offline   Reply With Quote
Old 08-10-2020, 08:14 PM   #2
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: Will the wheels I found fit my 67 stepside
10's might be a tight fit in your stepper wheel wells. Depends on how you lowered the truck. I know nothing about your truck though...
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 08-10-2020, 08:21 PM   #3
RenoKeene
Florida Edition
RenoKeene's Avatar
I see you wrote that your truck will be lowered so just fit everything up as you go. The wheel backspace will be the clincher. I'm running 8's with a 6" coil spring drop and they did rub a little pulling my Scotty trailer (light tongue weight).
Old 08-10-2020, 08:28 PM   #4
johnson1967
The back will be lowered with 4 in lowering springs from brothers idk if that helps.
Old 08-10-2020, 08:46 PM   #5
RenoKeene
Florida Edition
RenoKeene's Avatar
Coils right? Are you going with a shock relocator kit and a adjustable track bar? Is your rear end a stock 67 12 bolt?
You can mount your wheels and tires on the rear and measure the distance inside tire to inside tire then compare that to the bedside to bedside dimensions.
Old 08-10-2020, 09:07 PM   #6
johnson1967
Yes coil springs adjustable track bar and a shock relocation kit. Stock rear end.thanks for the advice . I'm waiting for the 5 lug conversion kit I'm ordering it next week these wheels are 5 lug.
Old 08-11-2020, 09:20 AM   #7
68Stepbed
68Stepbed's Avatar
If it's the stock 67 rearend with a 5-lug conversion, they'll fit fine, but you may experience some inner bedside rubbing when going around turns. If it's a 71-72 rearend, the tire bulge will be pretty flush with the fenders.
You said you're using an adjustable panhard bar, which will be important for getting the rear centered correctly.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-11-2020, 09:21 AM   #8
68Stepbed
68Stepbed's Avatar
What size tires do you intend to run?
Matt
Old 08-11-2020, 04:48 PM   #9
johnson1967
I'm not sure on tire size what do you think would work well
