08-10-2020, 08:17 PM | #1 |
6 Cylinder Fan Shroud
I have a 6 cylinder fan shroud. Surface rust in the bottom corners...slightly bent in some areas, but good overall condition.
Will disassemble for shipping, but will include the screws to put it as you see in the pictures. $70 shipped to lower 48. |
08-10-2020, 11:11 PM | #2 |
Re: 6 Cylinder Fan Shroud
Hey Andy, that shroud goes between the core support and the radiator to direct air flow from outside the truck directly into the radiator
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
08-25-2020, 03:50 PM | #3 |
bump
