Old 08-11-2020, 10:29 AM   #1
Thealien
Thealien's Avatar
Where to buy the big square body shims
Like the title asks Where to buy the big square body shims in different thicknesses. I can find plenty of panel shims but not the big square body mount shims?
Mark
Old 08-11-2020, 01:01 PM   #2
Mike C
Mike C's Avatar
Re: Where to buy the big square body shims
I made mine out of of 10ga plate cut into a square with hole drilled in middle.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-11-2020, 04:40 PM   #3
weq92f
weq92f's Avatar
I just used huge washers!
But...
https://www.oreillyauto.com/detail/b...6016ct/4243420
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 08-15-2020, 03:34 PM   #4
Thealien
Thealien's Avatar
But...
-klb
It doesn't say size anywhere but I think those are fender or cowl shims not the big body shims
Old 08-15-2020, 03:50 PM   #5
weq92f
weq92f's Avatar
This particular one is: Steel Body Shim; 1/8" Thick. 3/8" Slot. 1-1/4" x 1-1/8"
I figured they had an assortment available though.
Hth,
-klb
Old 08-15-2020, 04:38 PM   #6
HO455
Post Whore
HO455's Avatar
Mcmaster Carr has these which are close to the size you stated.
https://www.mcmaster.com/97235K808/
RIP Bob Parks.
Old 08-15-2020, 04:58 PM   #7
Thealien
Thealien's Avatar
Thanks for the suggestions and links.
I am going to try and measure the actual size of the ones already in my Blazer. Really would like some original ones.
Old 08-15-2020, 06:33 PM   #8
HO455
Post Whore
HO455's Avatar
Where are they being used? The large cab mount bushing? I am pretty sure that they factory didn't use different thickness washers or shims. Once the cab was basically dropped on the frame everything else got adjusted to match the cab. GM manufacturing processes were meant to be quick so having a bunch of shims to try and align the cab perfectly didn't make financial sense.
Now in the 50 or so years sense some could have been added after an accident or for other reasons
My Burban had no shims installed when I replaced the body mounts on it. (See my nice collection of rust!) As long as the body on a Suburban is GM saw there was no need for shims. So I can't see how a truck cab would need them from the factory. Unless the body mount was bent during assembly and needed to be cobbled up to get it out of the door.
Now I could be wrong if someone knows for sure please correct my theory.
RIP Bob Parks.
Old 08-15-2020, 06:48 PM   #9
Thealien
Thealien's Avatar
Could be a Blazer thing due to the removeable top? I have had 3 Blazers and they all had the same big square shims. It is called out in the assembly manual to get the windshield frame to door gaps right.
Old 08-15-2020, 09:36 PM   #10
HO455
Post Whore
HO455's Avatar
I've never had a big Blazer so I know even less than usual.
You might try reposting in the Blazer section, or have a Moderator move your thread.
Good luck.
RIP Bob Parks.
Old 08-16-2020, 09:56 AM   #11
Thealien
Thealien's Avatar
I tried taking a picture and measuring it but it is in a tight spot. As I said I have had the same square body mount shims on 3 separate Blazer and Jimmy vehicles.
Old 08-18-2020, 08:34 PM   #12
davischevy
davischevy's Avatar
They were installed on some C10's also.
I only have one left and was wondering about sources also.
EDIT; As far as I can tell, they were installed on an as needed basis.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 09-03-2020, 04:30 PM   #13
Richard
Came across these a few days ago and just now remembered this thread There are other sizes as well https://www.lowes.com/pd/Simpson-Str...E&gclsrc=aw.ds
Richard
