Old 08-12-2020, 12:28 PM   #1
A1971Blazer
A1971Blazer's Avatar
'67 power steering upgrade
On this '67 I just bought, I want to add power steering.
After much research, I have seen that the '67 frames did not have the dished area on the frame where the steering gear mounts.
Obviously this one does (picture) which is probably a good thing...
The numbers stamped on top of the frame rail near the gear do not match anything on the VIN number.
Not that I'm overly concerned about it because I have a good clean title and where I live there is no "inspection" of a vehicle this old....
but am I to assume this is likely a later model frame? Or perhaps a very late production '67 that had a '68 style frame.
Are there other identifying attributes that would identify it?
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 08-12-2020, 12:36 PM   #2
weim55
Re: '67 power steering upgrade
VIN number stamped on your frame should have a sequence like this:
7Z661642
The first digit before the letter is the year, in this example ‘7’ is 1967. 1972 could be different. Some others might chime in here who have seen more differences then I have.
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 08-12-2020, 12:46 PM   #3
A1971Blazer
7Z661642
That may help....
here is the number stamped on the frame
1967 C10 Step side
1968 C10 Step side
Old 08-13-2020, 11:18 AM   #4
weim55
So yes, your first digit ‘9’ Indicates your frame is of 1969 manufacture.
Old 08-13-2020, 11:24 AM   #5
A1971Blazer
After looking at your first reply and then at the ID number...that looks to be correct.
In the end it's not really gonna matter to me....but it will make adding a power steering gear a simple bolt on swap.
I'll be sure to spec chassis parts for a '69
Thank you for helping me to clear it up.
1967 C10 Step side
1968 C10 Step side
