Old 08-13-2020, 07:24 AM   #1
Minkota
Radiator Cap PSI
Currently my system has a 7PSI Cap installed but it will start spitting water after it is shut down. what PSI is recommended for a 383 small block with 50/50 mix and Vintage Air.
Minkota is offline   Reply With Quote
Old 08-13-2020, 08:36 AM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Radiator Cap PSI
Stock is 15 - 16#. I don't see any reason your 383 would be any different. If you don't already have an overflow tank, it's a cheap, easy, effective upgrade. You'll need a cap for a sealed system (if you have a tank).
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 08-13-2020, 09:01 AM   #3
Minkota
I was more concerned with the Vintage Air being installed than the 383. truck does not have an overflow tank.
Old 08-13-2020, 10:53 AM   #4
54blackhornet
54blackhornet's Avatar
7lb is to low to raise boiling point much.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 08-13-2020, 12:05 PM   #5
sick472
sick472's Avatar
All the older (pre-72) vehicles that I have had the pleasure of owning would puke coolant after shut-down...IF it was filled all the way to the top. Try this, let it do it's puking a time or two (if it even needs to puke twice), let it cool, look into the radiator and do not fill it over that mental mark. Typically, I find that the appropriate level lands at the top of the fins.
I'm not saying that the 7psi cap is appropriate as all of my older cars have that 15-16# cap. Changing it to a 15-16 cap will increase the boiling temp of 50/50 coolant by about 22 degrees F. This helps IF you car tends to run close to 268 degrees F and is actually boiling the coolant....BUT, it your not running that hot and not boiling your coolant...the coolant will still expand at the same rate when it gets hot regardless of the cap pressure rating (within reason). I would bet you are not boiling your coolant, just heating to up. This causes fluid expansion and you just don't have anywhere for it to expand. Leave some room in the radiator for it to expand or add an expansion tank.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 08-13-2020, 01:02 PM   #6
MJN
MJN's Avatar
What your concern with the Vintage Air? The A/C isn't tied into the cooling system other than having the condenser out in front of the radiator and as with any stacked cooler design transfers heat from itself to the radiator. Do you have a fan shroud or any overheating issues?
I agree with the others, get a 15/16 lb cap and leave room in the radiator for coolant expansion when it is hot.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 08-13-2020, 02:27 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Agree with the above -- 7 psi is the wrong cap, and your A/C has nothing to do with that. Leave your coolant level low or add a tank so you can fill the radiator.
- Mike -
RIP El Jay
Old 08-13-2020, 02:44 PM   #8
Minkota
I tried that and it doesnt stop puking until the radiator is down 1-1/2 gallons.
My only concern with the AC was that it may possibly be putting slightly more load on the motor, causing a slight increase in temp.
I know some people use 7psi to avoid premature wear on radiator and heater core, but thats not really a concern of mine. I have always run at minimum a 13psi but wasn't sure what the recommended psi was.
Old 08-13-2020, 04:33 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Well, that sure doesn't seem normal -- that is a lot of coolant to lose.
At the very least, I would suggest a sealed system with a recovery tank. If you're not overheating, that may be all you need. More than that, though, how's the rest of the cooling system? Radiator, hoses, water pump all in good condition? Fan shroud the correct size & shape, and the fan sitting ~ halfway into the shroud? Heavy Duty fan clutch with a six - seven blade fan? Just some of the basics to consider for an effective cooling system.
- Mike -
RIP El Jay
