08-13-2020, 09:50 AM | #1 |
Got two big accomplishments done
Well I finally got some major miles stones done.
1) I now have a rolling chassis!! 2) I came up with a name for my truck "Snowball" The reason is it started out as take the sheet metal off for painting. But Resulting in: -Finding out the frame was tweeked. So I replaced the '67 with a '71 -Converting it to a SWB -Relocating the gas tank to the rear -Converting the rear axle to five lug -Converting the rear to disc brake -Adding front and rear anti-sway bars -Blasting the frame and painting it -Replacing all the suspension components So as you can see the name fits. Now I just need to get the passenger door cleaned up. The bottom inside corners are rotted out, had at least three different mirrors on it and it took a hit in it. After dealing with repro parts I'd rather put the time in fixing the door than fighting with a repro parts. |
08-13-2020, 10:38 AM | #2 | |
Re: Got two big accomplishments done
08-13-2020, 01:46 PM | #3 |
Ok Sheepdip here are some pics of my project.
08-13-2020, 04:59 PM | #4 |
20' Daredevil (Ret)
"Snowball" would be a fitting name for a lot of these trucks, including mine.
Looks like your project is off to a great start!
08-13-2020, 05:54 PM | #5 |
Cool!!! Can't wait to see pictures!!!
My 67 frame is getting replace with a 72. All the pieces are there, but in poor condition, so I already have the 5 lug stuff, Thank You, Lord!!! Mine will have a rear gas tank, before it gets on street, again!!! I prefer long beds, so I won't be copying, you, there!!! I already have a new sway bar, and all the suspension parts... |
08-13-2020, 06:36 PM | #6 |
08-13-2020, 09:00 PM | #7 |
Will do Sheepdip. One thing I forgot to mention is I also relocated the battery box to the passenger frame rail behind the cab. Didn.t cost me anything as I modified the factory one to work.
08-21-2020, 11:44 PM | #8 |
Today is a another BIG day. Patched and welded up the last to the rust holes. Think I'll have a beer tonight root beer that is. Real beer makes me do stupid things.
08-22-2020, 09:41 AM | #9 |
Perfect Name!
Where did you get the rear sway bar, and does it make much difference? Years ago I put the one on the front, and it was a huge improvement |
08-22-2020, 12:55 PM | #10 |
Nice touch with the fuel line routing.
08-23-2020, 09:40 PM | #11 |
Thanks guys. This project has really started to roll along now that all the rust work is done. I even did a spray out of my exterior paint, Pantone 331. Its on the order of seafoam green but a shade or two lighter. Interior will be distressed saddle and the glass is grey tinted.
As for the rear sway bar its from Classic Car Products. Its 1-1/8" in diameter and the part number is CCP7401 (Summit Racing. As for how well it helps handling that answer will be in six months to a year from now. |
