08-15-2020, 08:07 PM | #1 |
3/4 ton axle relocation
On a half ton truck you can move the rear axle back 2 or 3 inches by using springs from a heavier rated truck. This is not normally a desired effect and corrected by shims or easy inches. In my case, 2 or 3 inches back would be the intended result...problem being that I have a 3/4 ton and already have 56 inch springs out back. Are there any spring alternatives that would move my axle back with the stock perch locations or is drilling and relocating the perches my only option?
1978 Scottsdale - celebrating 10 years of teaching me profanity 1990 Silverado - bought in Nov. 2016 and it's already catching up - Sold 1987 k5 blazer - sold... :\ seed money for the 81 1981 k20 4x4 - 5.3 swap in progress Events attended: Spring GOG 2011 Dale JR car show Summer 2012 Gathering at Tommys pickup parts |
08-15-2020, 08:54 PM | #2 |
Re: 3/4 ton axle relocation
the gm 52" 1/2 ton and light 3/4 ton springs are centered eye to eye .
gm 3/4 and 1ton 56" rear springs are +4" on the back end of the spring pack . just flip the whole pack end to end to push back 4" . otherwise its off set axle plate shims or aftermarket new weld on perches for up to 1.5" movement . or have springs made the way you need them . or find springs from another vehicle that can work for you .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
