08-17-2020, 07:04 PM | #1 |
72 C-20 Help
Does anyone no what this wire is for its off the junction on the drivers side fender the PO installed a HEI Distributor the other and of has a round fastener on it i dont have a voltage regulator the PO converted the distributor does the the wires on the distributor look right its putting out 14 amps Thanks for the help Saddletramp
08-17-2020, 07:17 PM | #2 |
Re: 72 C-20 Help
Possibly for a dual battery. Should have nothing to do with the HEI
08-17-2020, 07:44 PM | #3 |
Re: 72 C-20 Help
Thanks for the answer do the wires on the distributor look right ?
08-17-2020, 08:13 PM | #4 |
Re: 72 C-20 Help
If this is what your talking about it's the alternator. Splices should be a little neater and bare wires need some insulation
08-18-2020, 05:29 PM | #5 |
Re: 72 C-20 Help
Afternoon Sir my Bad i ment alternator very tired when i posted it working 6 days a week Thanks for the response
08-18-2020, 05:32 PM | #6 |
Re: 72 C-20 Help
No biggy thought maybe you posted a different picture than you planned
08-21-2020, 11:40 AM | #7 |
Re: 72 C-20 Help
Your positive battery cable should have a small wire that comes off of it at the battery connection. This wire connects to a fusible link and then the fusible link connects to the junction block on the passenger fender. The junction block and associated wiring with 2 small inline fuses are what powers your volt meter. It has nothing to do with the HEI operation.
72 C10 lwb fleetside -stock 350/350 combo Last edited by 68 P.O.S.; 08-23-2020 at 08:36 PM. |
08-21-2020, 11:45 AM | #8 |
Re: 72 C-20 Help
Here's a thread that shows it a bit http://67-72chevytrucks.com/vboard/s...d.php?t=341604
72 C10 lwb fleetside -stock 350/350 combo |
