Old 12-14-2003, 05:56 PM   #1
JJR
JJR's Avatar
Testing Tach Cluster Not Installed
I have a tach/air pressure cluster I got out of a C-60 a while back and am getting around to trying to see if the tach works. My service manual does not appear to show how the tach was installed. The tach has two connections, one for 12V and one for the coil. Is it as easy as running a wire to the coil (negitive side)and switched 12V connection? Seems like there needs to be a ground somewhere. I am use to hooking up my dwell meter to ground and the coil so I just want to make sure I don't fry the tach (if it isn't already fried). Thanks.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 12-14-2003, 06:54 PM   #2
Piper71c10
Unending Project
Piper71c10's Avatar
On mine there was a stud just under the two flat connectors. It's not labled, but I assumed that was ground. It works fine with my ground hooked up there.
Piper
Piper71c10 is offline   Reply With Quote
Old 12-14-2003, 07:56 PM   #3
Duffy
the tach, is grounded through the housing. You should be able to run a ground wire from any of the screws that hold the cluster together. There may be a seperate ground terminal on the back of the cluster.
Good Luck...
Duff
'72 GMC Sierra Grande Custom Camper
Duffy is offline   Reply With Quote
Old 12-14-2003, 11:43 PM   #4
JJR
JJR's Avatar
Thanks for the reply's. Mine has the stud also so I will ground it there. I will test it tomorrow. Hope it works but I can't complain if it doesn't, I only paid $35 for the whole cluster. It has a bad printed circuit and a little yellowing but other than that it is OK.
