Old 08-19-2020, 05:02 PM   #1
hooverfish
hooverfish's Avatar
Under Hood A/C Actuator - Help needed
My actuator under hood not working, noticed the rod that goes through the firewall seemed loose/not connected.
Pulled off the cowl panel and yes, its got broken parts under the cowl. Doubt the assembly is reproduced ??
Second picture of plastic rubber plate seems to be broken on both ends.
Anyone else run into this ?? Is the door in the heater that this controls, very important for cooling ??
Searched for pictures and threads but didnt find much. Drawing is Assembly Manual not helpful.
What other parts am I missing (I have the screws that are not shown in first picture) ?
I know I can get the actuator and install, but need help with the under cowl stuff and how to connect it.
Any help, advice appreciated.
Larry
84 Chevy SWB, "Roy", dark blue orig paint, 6 cyl auto, PS, 88,000 miles.
72 Highlander LWB "Olive" med olive over lt yellow, air, 77,000 miles (sold)
"It's a sorry man who can't find his wife a good job"
hooverfish is online now   Reply With Quote
Old 08-19-2020, 05:40 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Under Hood A/C Actuator - Help needed
These may help.
http://67-72chevytrucks.com/vboard/s...d.php?t=809842
http://67-72chevytrucks.com/vboard/s...d.php?t=478564
http://67-72chevytrucks.com/vboard/s...d.php?t=674249
Jim
FirstOwner69 is offline   Reply With Quote
Old 08-19-2020, 07:59 PM   #3
hooverfish
hooverfish's Avatar
Hello Jim
Yes, that helps A LOT !
Thank you, I feel much better knowing that part is available.
And also the pictures and discussion are very helpful for me.
Larry
Old 08-20-2020, 02:27 PM   #4
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
That's a common break point, the door is too heavy for how they attach. I have one that looks exactly like the original, only it's a lighter door. Might have been a GM replacement.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-22-2020, 06:02 PM   #5
hooverfish
hooverfish's Avatar
Got the new fresh air door from LMC today. Trying to install but .... the small rod with spring doesn't seem to be long enough where it goes into the firewall.
See the yellow arrow in picture. New part has same rod length as original part rod length ??
Am I missing a part or washer or supposed to shim something ?
EDIT: I modified the spring loaded rod so it's now long enough to go into the fitting on the firewall. All good.
Larry
