Old 08-20-2020, 06:33 AM   #1
bigmac73
bigmac73's Avatar
bench seat thought
Guys,
just wanted to run this by you guys .
I am thinking of using some 1 x 5 rectangular tubing to use as a shim/ spacer to raise my seat an inch to allow for more room for speakers underneath.
and instead of using the the standard bolts going with a stud and washer/nut
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 08-20-2020, 09:28 AM   #2
Davidf
Re: bench seat thought
Don't do that, just cut the doors for speakers
Seriously, I think the seats are already too high. I'm 6'-5" and look through the tint band on the windshield most of the time. And, raising the seat will put the steering wheel super close to the seat bottom.
I am in the process of fixing all the rust on my truck and repainting. As such, I patched the speaker holes in both doors and went with kick panel speakers as I still rock the in cab fuel tank so the cab corners were not an option.
Davidf is offline   Reply With Quote
Old 08-20-2020, 03:03 PM   #3
bigmac73
bigmac73's Avatar
well I run around 6'3 and 300 Lbs thank god for tilt LOL
I already have the kick panel speakers but was thinking about these to augment the 6.5 speakers and i figured it would not hurt to add a inch of room underneath, although these might fit fine...And i am leaving the tank in the cab.
https://www.amazon.com/gp/product/B0...SDHDORFF&psc=1
Mike
