08-20-2020, 08:09 AM | #1 |
Deadhead fuel pressure regulator
I need some guidance. I have a 72 K-20 with a 350 small block, 1406 Edelbrock carburetor and the stock mechanical fuel pump. The engine is running a little rough at idle and the exhaust smells rich. I tested the fuel pressure and it bounces from 8-9 psi (seems high for a mechanical fuel pump).
I searched the site for guidance on a deadhead fuel pressure regulator and there seems to be conflicting information. Some say a deadhead pressure regulator will damage the mechanical fuel pump. What’s the best option for a regulator or should I go in a different direction? |
08-20-2020, 10:29 AM | #2 |
Re: Deadhead fuel pressure regulator
Yikes, 8-9psi is too hi for an Edelbrock carb. They need no more than 6psi, or else they start to flood. I can't help on the regulator, I went with an Edelbrock fuel pump to solve that problem.
I see you're a new member, welcome aboard!
72 C10 lwb fleetside -stock 350/350 combo |
08-20-2020, 07:21 PM | #3 | |
Posted via Mobile Device |
