08-20-2020, 07:51 PM | #1 |
How did you install your floor hump?
They take a rubber gasket. I believe GM used body seal along any glaring cracks between the floor and hump, and sprayed with the hump bolted on. Sound right?
Is there are better way or sealant? Personally I don't care if it's finished on or off the cab floor, just need to account for it. Thanks
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-20-2020, 10:33 PM | #2 |
Re: How did you install your floor hump?
I've used weather strip caulking strip made by 3m otherwise known as "dumb dumb" after everything is painted. The high humps have a nice channel that it lays in and you can go around the bolts. It fills the gap areas good and smashes out of the tight areas. If you ever need to take the hump off the dumb dumb stays pliable and doesn't dry
1971 LSX "Bonnie" build thread http://67-72chevytrucks.com/vboard/s....php?p=8026381 paypal is curtbarton1971@yahoo.com |
08-21-2020, 10:46 AM | #3 | |
08-21-2020, 10:48 AM | #4 |
All about them K’s
I used 2 layers of butyl tape stacked on top of each other on mine.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 08-29-2020 at 04:37 PM. |
08-23-2020, 02:41 PM | #5 |
Thanks for the replies. I took a note there was a gasket underneath, but I didn't note a description. Since I no longer have it I'm assuming it was a sealant. That said, what is the "Adapter assembly" piece they're referring to in the manual, page 68? It's #3.
08-29-2020, 04:29 PM | #6 |
Old member
My 67 ramp truck hump is self tapping screws with some foam I got at work they use for insulation. I cut a 2" wide pattern out to fit the hump. Then bought 2 floor mates at Home Depot to cover the floor with.
08-29-2020, 05:32 PM | #7 |
...no they don't, but my Stepside comes really close!
Dang it you guys, I didn't even know there was a replaceable hump. So when I switched from a column shift 3 speed manual, to a floor mounted 3 speed auto stick, I cut a big ol' hole in the hump for the shiftier. The thing didn't even have a reverse lock-out, and one day I came to a red light, and a 2-liter bottle flew off my old bench seat and...SCREECH! ...that Turbo 350 tranny is still hanging in there all these years later...AMAZING. So I put a B&M ratchet shifter in its place, and kind of patched the hole. Now all I really need is a tiny hole for a shifter cable. So where do you get a transmission hump, just in case I want to undo my messup someday? Oh BTW, I do carry a fire extinguisher, have for years, just hope I never have to use it. |
08-29-2020, 05:46 PM | #8 |
They sell humps on-line. don't know how good, but there's a Youtube of a guy installing one have he cut out the floor, he seemed happy with it.
08-29-2020, 06:33 PM | #9 |
You can make your own gasket out of a thick bead [3/8''] of RTV. Squirt it out on the outside rim of the floorpan, and set strips of wax paper over the RTV, then put your hump cover on lightly. Start the bolts but do not torque them home. Let it set up overnight. In the morning, if it hardened, peel off the wax paper and secure the bolts.
I posted this exact same advice some years ago, but I dunno where old threads go. Hey Andy, tell us more about the diamond tread stuff on your cab floor. I think I like your deal. Maybe post a new thread about it, otherwise We'll be accused of wilfull and flagrant hijacking.
08-29-2020, 07:59 PM | #10 | |
Old member
http://67-72chevytrucks.com/vboard/s...68#post8799968
08-30-2020, 07:28 AM | #11 |
I used this on mine and it's worked great. I've had that cover off a couple of times since and it's never come loose.
https://www.menards.com/main/hardwar...252-c-3624.htm
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
08-30-2020, 10:12 AM | #12 |
Yes I like that diamond carpet as well, great idea! Seems I'm always spilling some liquid on the floor.
Thanks for the information. |
