08-21-2020, 06:08 PM | #1 |
Inner Rocker Panel Bolts
Anyone have a part number or link for inner rocker panel bolts?
Thanks! |
08-23-2020, 06:50 PM | #2 |
Re: Inner Rocker Panel Bolts
bump, i want to know too.
1972 C20 |
08-23-2020, 09:55 PM | #3 |
double bump,
08-23-2020, 10:23 PM | #4 |
Bolts or nuts?
08-24-2020, 09:44 PM | #5 |
1972 C20 |
08-25-2020, 11:52 AM | #6 |
The nuts are a square nut that is spot welded on back at the cab corner section. 3/8-16. The bolts have a washer made on then with a pointed end. I found some on ebay when I converted my low hump floor to a high hump. They were 5/16 nuts and I spot welded them in place.There is a special name for the nuts but I don't remember.
08-25-2020, 11:56 AM | #7 |
Picture. I also added the nuts under the floor to add bucket seats and made some custom floor braces.
08-25-2020, 05:34 PM | #8 |
I bought some home depot standard 3/16" nuts/bolts washers and have them in place for the time being. I originally wanted to use the factory style welded nut as shown in that photo, however I am not sure there is a real advantage to this for the A/B pillar application?
If you ever have to loosen these bolts, you're not adjusting the B pillar without having the rocker off anyway? Not sure if there is a pro or con to the A-pillar application. I didn't mean to hijack this thread, just wanted to confirm if there is a true advantage before hunting down those pieces. I hope this is still applicable to the OPs post! Thanks!
1972 C20 |
08-25-2020, 08:31 PM | #9 |
I usually put some in my pockets when at the pick a part...
https://www.google.com/search?client...=gm+body+bolts |
08-26-2020, 01:08 AM | #10 |
On mine I actually just welded regular nuts and have new bolts. I'm going to raptor line the underneath anyways,so you won't even tell anyways.
09-06-2020, 07:18 AM | #11 |
Thanks for the answers everyone!
09-06-2020, 10:39 AM | #12 |
The nuts I used are called square nuts got them at the local hardware store and just automotive body bolts again from my local hardware store
09-06-2020, 10:29 PM | #13 | |
Bolts =''Body Screws''. Nuts = ''Weld Nuts''. "J-Nuts" have a reach-around clip. "Clip Nuts" have spring clips on 2 sides and are held in a place by spring tension. [Used on '67-'71s to attach the door panels.]
