Old 08-22-2020, 05:24 PM   #1
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Dimple frame vs shimming steering box?
I know when converting to power steering on a 67 it is necessary to provide clearance for the box. However I don't have access to a torch to dimple the frame which I know is the preferred method. Has anyone shimmed the box or would this adversity affect the steering in some way?
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 08-22-2020, 05:46 PM   #2
HO455
Post Whore
HO455's Avatar
Re: Dimple frame vs shimming steering box?
Lots of folks have shimmed their boxes. The down side is that with the box moved over you may find that your turning circle won't be the same in both directions.
RIP Bob Parks.
Old 08-22-2020, 07:07 PM   #3
Grumpy old man
Grumpy old man's Avatar
You don't need a huge divot in the frame to make it fit , if you have a cutting wheel and some map gas/ propane torch and a mig welder you can move it enough to work , You'll also have to grind some off the front core support bracket . and then get some stainless lines from Pickmup
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 08-22-2020, 07:09 PM   #4
geezer#99
geezer#99's Avatar
You are assuming the frame isn’t already dimpled!
Some 67’s were.
A pic of yours will help.
Old 08-23-2020, 06:23 AM   #5
swb4me
A third option exist for power steering on a 67. Buy a cpp steering box cp50014. This thread has pictures and does a good job of explaining why this box doesn't need shimmed or a dimple made.
https://67-72chevytrucks.com/vboard/...d.php?t=729738
swb4me is offline   Reply With Quote
