Old 08-23-2020, 06:26 PM   #1
ItWillBeSlow
ItWillBeSlow's Avatar
Replacing cab corner and B pillar - is this gap normal?
All,
I am almost done with all my passenger metal work. I have replaced the bottom of the A/B pillars, the inner rocker/edge of floor, cab corner, and am currently "working" the rocker to get it to sit right.
After finishing the cab corner, and while working on the rocker, I noticed this 1/4" gap between the cab corner and the bottom of the B pillar. This is completely open to the outside. The other side is too rusted/bondo'd for me to compare to factory. These are tri-plus parts that appear to fit fairly well otherwise. This is my first attempt at this work and all seems to have gone well do far, I believe everything to be in the correct position and fairly well lined up. The B pillar/door seam appears straight all the way down and does not appear to be kicked forward at all, especially enough for this gap.
Ideas?
1972 C20
ItWillBeSlow is offline   Reply With Quote
Old 08-23-2020, 06:47 PM   #2
Richard
Re: Replacing cab corner and B pillar - is this gap normal?
Not to uncommon to see fitment like that from the factory. You will see very large globs of sealer applied in those areas in un-molested trucks. Even the rocker to cab corner would have 1/4" plus gaps. Of course you have the choice to tighten up the gaps or even eliminate them. It is your truck. Anyone that says those gaps are not correct has not seen a lot of these trucks.
Richard
Old 08-23-2020, 07:55 PM   #3
Davidf
Yes, that’s normal. Outer rocker cover covers the gap.
Davidf is offline   Reply With Quote
Old 08-23-2020, 08:06 PM   #4
ItWillBeSlow
Thanks guys. I am surprised to hear this is normal, that is a large gap to fill with sealer. The outer rocker will visibly cover it but it is still a large opening for moisture and noise to come in, I am assuming no one is leaving it as-is.
What is everyone doing to close this up?
1972 C20
Old 08-23-2020, 09:55 PM   #5
bhemingson
you have to make up a filler piece. My '72 had so much sealer in there it looked like they used a soft serve ice cream dispenser.
bhemingson is offline   Reply With Quote
Old 08-24-2020, 07:06 AM   #6
clay68c10
clay68c10's Avatar
I’m just finishing up my corners and rockers. That “gappy-ness” is about the same as mine. It’s more that what the factory panels have overall, but you work with what you have.
The biggest difference I noticed is where the corner and rocker meet on the outside. The repro parts just don’t have as crisp of an edge stamping as the factory. Again, you have repro parts so that’s just the nature of the beast.
At least it’s down low so your eye isn’t drawn to it.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 08-24-2020, 08:50 AM   #7
Davidf
the cab corner in rear (where meets floor pan also has a large gap filled with seam sealer from the factory.
For the gap (this thread), I seam sealed the outer rocker cover to the cab corner only.
Old 08-25-2020, 01:23 PM   #8
kidatheart
kidatheart's Avatar
Nice work!
kidatheart is offline   Reply With Quote
Old 08-25-2020, 05:37 PM   #9
ItWillBeSlow
Originally Posted by kidatheart View Post
Nice work!
Thanks! Its my first attempt and I am happy so far. I'm looking forward to getting to the other side and knocking it out a little quicker with one half under my belt.
1972 C20
Old 09-01-2020, 06:58 PM   #10
May70
May70's Avatar
Had the same issue.
I basically redid that whole pillar patch. For the DS I probably wont even bother using the patch panel I ordered. More pics will be in my signature link to my project, once I get a minute to put them all up.
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
