Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 08-24-2020, 09:13 PM   #1
74CustomK20
74CustomK20's Avatar
New to 2 ton
Hello all, this is my first big truck, and am having some issues I haven't had on my k20's. Brakes are inop, wiring is worse than anything I've ever seen, the rear is stuck in low range, and the dump bed is leaking like a siv.
The bed works, so I can keep adding oil as needed and figure it out.
Is there anything special I need to know about these brakes? It's hydraulic, has a master cylinder...
The wiring is totally different than my k20. The k20 has a square block that the wires all pass through where the cab wiring meets the chassis and engine wiring, which I guess I'm used to. This c70 has a wide buss bar almost and it's a CLUSTER to say the least. My main question I guess is can I take a wiring harness from a half ton or equivalent truck and make that work on this 2 ton? If so that would be sooo much easier. If not, what or where can I find a wiring schematic? Is there anything specifically different between them?
Anything I need to know about these big heavy behemoths lol?
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
